Cannot access particle variables all of a sudden
I have run 3 Photons for years and have written Python code to access data and all of a sudden all of them stopped working. The only change that I made is enable two factor authentication. Does that impact access to Spark variables?
Now all requests seem to time out. I disabled two factor and the errors continue. To simplify things, I went back to curl to see if it works, it does not. Here is an example of what I am inputting and the response. I verified the devid and access token. (AccessToken from build.particle.io and devID from console.particle.com.)
curl https://api.particle.io/v1/devices/:DevID:\temp \
     -d access_token=7:AToken:
The result is:
{"ok":false,"error":"Not Found"}
What am I doing wrong? I have a feeling that changing to two factor may have caused this.
Thank you!
Update: I really think that I have encountered a bug of some sort. I run this curl query on all Photons and in ever case under “Variable”, it shows “null”.
curl "https://api.spark.io/v1/devices/:DevID:?access_token=:Atoken:"
However, if i go to console.particle.io, I see three variables defined for every Photon. Why am I seeing variables in the console and not in the API?
Thank you
Seems to be a thing. Been having issues all night…come check the forums and people are reporting issues.
Odd
Regards,
Jason
api.spark.io was depreciated. Could that be part of the problem?
That was it! I did not update all my python apps to the new url, and I was using curl to go to the old end end point. Thank you!
