Hi i am tinkering with the android example app.I can read a variable from photon but i cant run a function on my photon.I am using the code from particle docs:
int resultCode = someDevice.callFunction(“digitalwrite”, list(“D7”, “1”));
in my case I have a function led which takes a parameter on,off to turn on/off photon 's led.
my code is
int resultCode = someDevice.callFunction(“led”, list(“on”));
I get an exception FunctionDoesNotExist
Help anyone?
That error is exactly what it sounds like: according to the last update from the Particle cloud, there was no such function found on that device!
If you retrieve the raw JSON for that device with curl, does the “led” function appear in the list of functions?
curl does work fine and so does IFTT
I had this same error and just solved it. I needed to call the function inside a try/catch. For example
try {
device.callFunction("toggle");
} catch (ParticleDevice.FunctionDoesNotExistException e) {
e.printStackTrace();
This may be too late for you, but hopefully it can help someone else.
