Hi there, I’m trying to make my first Arduino project with the Spark Core. I picked making a universal IR remote that Instructables has on their website. I’m trying to compile their IR_RECEIVE.ino which includes using raw pin reading methods. When
I’ve changed line 19 to
#define IRpin_PIN PINB
and it’s not compiling. Neither was the original definition as PIND. I just get
'PINB' was not declared in this scope.
Is there something I’m missing that I have to include or is this not a capability of the Spark Core?
digitalRead() is a macro, so it runs slower than using Direct Port Manipulation, you can see the notes in his code:
// while (digitalRead(IRpin)) { // this is too slow!
while (IRpin_PIN & (1 << IRpin)) {
Since the Spark is a faster processor, try using digitalRead() by just changing his code to the notated version like this:
meanwhile, we can look to see how to get readings from the pins without the digitalRead() macro…
/* Raw IR decoder sketch!
This sketch/program uses the Arduno and a PNA4602 to
decode IR received. This can be used to make a IR receiver
(by looking for a particular code)
or transmitter (by pulsing an IR LED at ~38KHz for the
durations detected
Code is public domain, check out www.ladyada.net and adafruit.com
for more tutorials!
// We need to use the 'raw' pin reading methods
// because timing is very important here and the digitalRead()
// procedure is slower!
//uint8_t IRpin = 2;
// Digital pin #2 is the same as Pin D2 see
// http://arduino.cc/en/Hacking/PinMapping168 for the 'raw' pin mapping
//#define IRpin_PIN PIND
#define IRpin 2
// the maximum pulse we'll listen for - 65 milliseconds is a long time
#define MAXPULSE 65000
// what our timing resolution should be, larger is better
// as its more 'precise' - but too large and you wont get
// accurate timing
#define RESOLUTION 20
// we will store up to 100 pulse pairs (this is -a lot-)
uint16_t pulses[100][2]; // pair is high and low pulse
uint8_t currentpulse = 0; // index for pulses we're storing
void setup(void)
pinMode(IRpin,OUTPUT);
Serial.println("Ready to decode IR!");
void loop(void) {
uint16_t highpulse, lowpulse; // temporary storage timing
highpulse = lowpulse = 0; // start out with no pulse length
//while (IRpin_PIN & (1 << IRpin)) {
// pin is still HIGH
// count off another few microseconds
highpulse++;
delayMicroseconds(RESOLUTION);
// If the pulse is too long, we 'timed out' - either nothing
// was received or the code is finished, so print what
// we've grabbed so far, and then reset
if ((highpulse >= MAXPULSE) && (currentpulse != 0)) {
printpulses();
currentpulse=0;
return;
// we didn't time out so lets stash the reading
pulses[currentpulse][0] = highpulse;
// same as above
while (!digitalRead(IRpin)) {
//while (! (IRpin_PIN & _BV(IRpin))) {
// pin is still LOW
lowpulse++;
if ((lowpulse >= MAXPULSE) && (currentpulse != 0)) {
printpulses();
currentpulse=0;
return;
pulses[currentpulse][1] = lowpulse;
// we read one high-low pulse successfully, continue!
currentpulse++;
void printpulses(void) {
Serial.println("\n\r\n\rReceived: \n\rOFF \tON");
for (uint8_t i = 0; i < currentpulse; i++) {
Serial.print(pulses[i][0] * RESOLUTION, DEC);
Serial.print(" usec, ");
Serial.print(pulses[i][1] * RESOLUTION, DEC);
Serial.println(" usec");
BTW in Spark world digitalRead() is not a macro but a function.
If you want to know why it is so much slower than direct port access you can have a look in the Open Source files
Sorry, if I came across wrong - I didn't mean to be clever
This comment was mainly meant for @KlooShanko to show where to find some morw background info.
