Brand new Photon 2 keeps disconnecting and reconnecting to cloud
Hi guys,
I have 10 new photons; all of them except one seem to be working fine. One of them, no matter what I do keeps disconnecting from the cloud then reconnecting every 1 to 3 minutes. I've flashed, restarted, ran setup again, ran device doctor, etc.. all multiple times and with nothing on it (or a simple LED blink app) it still loops.
0000269541 [comm.protocol] ERROR: Event loop error 1
Any thoughts? None of the other 9 (which are right next to this device and have the same particle antenna, and are connected to the same wifi network) are having any issues.
Here's a log file, taken immediately after I ran setup again:
0000001497 [ncp.rltk.client] INFO: rltkOff
0000001541 [ncp.rltk.client] INFO: rltkOff done
0000001181 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000003937 [app] INFO: Auto-connect disabled
0000004660 [app] INFO: doing wifiScan
0000004701 [app] INFO: Doing Wi-fi scan
0000008773 [app] INFO: wiFiScan resultCount=30
0000021570 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000021648 [net.ifapi] INFO: Netif wl3 state UP
0000021697 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000021773 [ncp.rltk.client] INFO: Try to connect to ssid: MountainGang-5G
0000021849 [net.lwip_rltk] INFO: is_promisc_enabled
0000021902 [net.lwip_rltk] INFO: get_eap_phase
0000026849 [net.lwip_rltk] INFO: get_eap_phase
0000027115 [net.lwip_rltk] INFO: get_eap_phase
0000027400 [net.ifapi] INFO: Netif wl3 link UP
0000027448 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000027551 [hal] INFO: DNS server list changed
0000027600 [hal] INFO: DNS server list changed
0000027718 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
connection
0000028932 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000077172 [comm.dtls] ERROR: handshake failed -6800
0000077228 [comm.dtls] ERROR: Invalid handshake state
0000077285 [comm.protocol.handshake] ERROR: Handshake failed: 17
0000085175 [system] WARN: Internet test failed: DNS
0000085228 [system] WARN: Cloud handshake failed, code=-220
0000085540 [system] INFO: Cloud: disconnecting
0000085588 [system] INFO: Cloud: disconnected
0000085635 [system] INFO: Cloud: connecting
0000085680 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000085765 [system] WARN: Failed to load session data from persistent storage
0000085844 [system] INFO: Discarding session data
0000095318 [system] INFO: Cloud socket=0, connecting to 3.215.122.234#5684
0000095615 [system] INFO: Cloud socket connected
0000095665 [system] INFO: Starting handshake: presense_announce=0
0000095732 [comm.protocol.handshake] INFO: Establish secure connection
0000095806 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000099265 [comm.protocol.handshake] INFO: Sending HELLO message
0000099664 [comm.protocol.handshake] INFO: Handshake completed
0000099808 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000099876 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000100413 [system] INFO: Send spark/device/last_reset event
0000100920 [comm] INFO: Sending TIME request
0000101086 [system] INFO: Sending application DESCRIBE
0000101271 [system] INFO: Sending subscriptions
0000101321 [comm.protocol] INFO: Sending subscriptions
0000101924 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000102349 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000103178 [comm.protocol] INFO: Received TIME response: 1691636024
0000103538 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000103608 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000103803 [comm.protocol] INFO: Received DESCRIBE request; flags: 0x04
0000104609 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000104676 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000105134 [system] INFO: All handshake messages have been processed
0000105304 [system] INFO: Cloud connected
0000185643 [comm.protocol] ERROR: Event loop error 1
0000185699 [system] WARN: Communication loop error, closing cloud socket
0000185774 [system] INFO: Cloud: disconnecting
0000185822 [system] INFO: Cloud: disconnected
0000185869 [system] INFO: Cloud: connecting
0000185914 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000185998 [system] INFO: Loaded cloud server address and port from session data
0000186198 [system] INFO: Cloud socket=0, connecting to 3.215.122.234#5684
0000186496 [system] INFO: Cloud socket connected
0000186546 [system] INFO: Starting handshake: presense_announce=0
0000186613 [comm.protocol.handshake] INFO: Establish secure connection
0000186689 [comm.dtls] INFO: session has 0 uses
0000186743 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000186815 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,18, next_coap_id=c
0000186886 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=12
0000186977 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000187393 [comm.protocol.handshake] INFO: Skipping HELLO message
0000187576 [system] INFO: cloud connected from existing session.
0000187948 [system] INFO: Sending application DESCRIBE
0000188004 [comm.protocol] INFO: Checksum has not changed; not sending application DESCRIBE
0000188097 [system] INFO: Sending subscriptions
0000188146 [comm.protocol] INFO: Checksum has not changed; not sending subscriptions
0000188333 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000188844 [system] INFO: All handshake messages have been processed
0000189191 [system] INFO: Cloud connected
0000269595 [system] WARN: Communication loop error, closing cloud socket
0000269670 [system] INFO: Cloud: disconnecting
0000269718 [system] INFO: Cloud: disconnected
0000269765 [system] INFO: Cloud: connecting
0000269810 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000269893 [system] INFO: Loaded cloud server address and port from session data
0000270093 [system] INFO: Cloud socket=0, connecting to 3.215.122.234#5684
0000270390 [system] INFO: Cloud socket connected
0000270440 [system] INFO: Starting handshake: presense_announce=0
0000270508 [comm.protocol.handshake] INFO: Establish secure connection
0000270582 [comm.dtls] INFO: session has 0 uses
0000270635 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000270708 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,26, next_coap_id=11
0000270780 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=17
0000270871 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000271290 [comm.protocol.handshake] INFO: Skipping HELLO message
0000271474 [system] INFO: cloud connected from existing session.
0000271842 [system] INFO: Sending application DESCRIBE
0000271898 [comm.protocol] INFO: Checksum has not changed; not sending application DESCRIBE
0000271991 [system] INFO: Sending subscriptions
0000272040 [comm.protocol] INFO: Checksum has not changed; not sending subscriptions
0000272227 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000272650 [system] INFO: All handshake messages have been processed
0000272721 [system] INFO: Cloud connected
0000353345 [comm.protocol] ERROR: Event loop error 1
0000353399 [system] WARN: Communication loop error, closing cloud socket
0000353473 [system] INFO: Cloud: disconnecting
0000353521 [system] INFO: Cloud: disconnected
0000353568 [system] INFO: Cloud: connecting
0000353613 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000353696 [system] INFO: Loaded cloud server address and port from session data
0000353897 [system] INFO: Cloud socket=0, connecting to 3.215.122.234#5684
0000354195 [system] INFO: Cloud socket connected
0000354245 [system] INFO: Starting handshake: presense_announce=0
0000354313 [comm.protocol.handshake] INFO: Establish secure connection
0000354387 [comm.dtls] INFO: session has 0 uses
0000354442 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000354513 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,34, next_coap_id=16
0000354585 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=22
0000354676 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000355099 [comm.protocol.handshake] INFO: Skipping HELLO message
0000355283 [system] INFO: cloud connected from existing session.
0000355650 [system] INFO: Sending application DESCRIBE
0000355706 [comm.protocol] INFO: Checksum has not changed; not sending application DESCRIBE
0000355799 [system] INFO: Sending subscriptions
0000355849 [comm.protocol] INFO: Checksum has not changed; not sending subscriptions
0000356036 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000356548 [system] INFO: All handshake messages have been processed
0000356894 [system] INFO: Cloud connected
I don't know specifically what's wrong, but whatever it is, it consistently takes 80 seconds to occur:
I'd try increasing the logging level to LOG_LEVEL_TRACE so the keep-alive pings are logged. I'd guess that the first one works, and the second one has three retries then the connection is reset.
Hey Rick,
Thanks for the suggestion; there was a lot more info in that log level. To troubleshoot I connected the Photon2 to my cellphone wifi access point, and it wasn't dropping off at all. I connected it back to my home wireless network (where it continued to connect and disconnect) and I checked the router system logs. It was showing this:
2023/08/10 09:43:38 Kernel event ICMPv6 RA: ndisc_router_discovery() failed to add default route.
I googled that and it looks like it's a known issue with the router / modem I have. I rebooted and haven't seen the error with that Photon2 since (for a few hours now anyways).
Thanks again for the reply! Hopefully it's all working now.
