Hey I am testing out some logic when it comes to putting the Boron into sleep mode and according to the documentation it should wake on a function call but that doesnt seem to work. This is how I have it set up:
if (millis()-lastOn > onMinutes*60*1000) {
RGB.control(true);
RGB.color(0, 0, 0);
Particle.publish("status", "off", PRIVATE);
config.mode(SystemSleepMode::STOP)
.network(NETWORK_INTERFACE_CELLULAR)
.flag(SystemSleepFlag::WAIT_CLOUD)
.duration(offMinutes*60*1000);
SystemSleepResult result = System.sleep(config);
Particle.publish("status", "on", PRIVATE);
RGB.control(true);
RGB.color(0, 0, 128);
// Remember when we published
lastOn = millis();
but when it is in sleep mode calling the function fails. Looking in the docs it says:
The first example configures the cellular modem to both stay awake and for the network to be a wake source. If incoming data, from a function call, variable request, subscribed event, or OTA request arrives, the device will wake from sleep mode.
but it fails, do I have it correctly configured for "wake on network"?
