Hello,
For any reason, sometimes when I power on the Boron it get stuck on blinking green, sometimes blinking white, in some cases when it gets to blink white, I get a yellow blinking answer (which I think is not in the documentation by the way).
Anyway, if I reset the module (pressing the button) it connects inmediately after ±40 seconds. On the contrary, if I dont reset, it gets failing to connect forever. So I would like to make an algorithm such as when its been 70 seconds after startup with no connection it has to reset itself.
My question is, is it possible to do this? I was reading the documentations and It seems that I need the semiautomatic mode. But it seems that I cant do anything when it is trying to connect to the cloud, because the code gets paralyzed. I tried to do a routine on startup function but all I got was a brick module unable to connect to the network.
Many thanks
