Boron flashes red sos when loading program that reads and writes EEProm
Could you share the code? And what version of Device OS are you using?
#include <string.h>
#include <math.h>
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
int moisture;
int moist;
bool flag = false;
char CID[20];
String a;
String b;
String c;
//String n;
String r;
String con;
String d1;
String e1;
String t1;
String w1;
//String myString;
int d;
int e;
int t;
int w;
pinMode(A0, INPUT);
pinMode(D7, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D1, OUTPUT);
Particle.variable("moisture",moisture);
Particle.variable("moist",moist);
Particle.variable("con",con);
Particle.function("led", Led);
Particle.function("led1", Led1);
Particle.function("led2", Led2);
Particle.function("wtr",Wtr);
//String c=EEPROM.get(0,CID);
//String con=EEPROM.get(21,CID);
Led(a);
Serial.println(con);
int Total=0;
for (int i=1; i<=100; i++)
Total = Total+ analogRead(A0);
delay(10);
Total=Total/100;
moisture = Total;
int i1 = con.indexOf(',');
int i2 = con.indexOf(',', i1+1);
int i3 = con.indexOf(',', i2+1);
d1 = con .substring (0,i1);
//Serial.println(d1);
e1 = con .substring (i1+1,i2);
// Serial.println(e1);
t1 = con .substring (i2+1,i3);
//Serial.println(t1);
w1 = con .substring (i3+1,i3+3);
//Serial.println(w1);
d = d1.toInt();
e = e1.toInt();
t = t1.toInt();
w = w1.toInt();
//Serial.println(d);
//Serial.println(e);
//Serial.println(t);
//Serial.println(w);
String f= c.substring(0,4);
//Serial.println(f);
String g= c.substring(4,8);
//Serial.println(g);
float h = f.toInt();
float i= g.toInt();
float m = 100/(i-h);
float n = -(m *h);
moist = n -( -m*moisture);
//Serial.println(moist);
//Serial.println(moisture);
//Serial.println(c);
if (moist >=d ){flag = false;}{}
if (moist <d and moist>=e and flag == true){Wtr(a); }
if (moist <e){Wtr(a); flag = true; }
previousMillis = millis();
currentMillis = millis()+1;
loop1();
int Led(String command)
{ a = command;
int Total=0;
Total=0;
delay(10);
Total=Total/100;
Serial.println(con);//Serial.println(Total);
moisture = Total;
Serial.println(c);
Serial.println(g);
float i= g.toInt();
float n = -(m *h);
if (moist >= d ){flag = false;}{}
if (moist < e){Wtr(a); flag = true; }
Particle.publish("moisture",String(moisture));
Particle.publish("moist",String(moist));
return 1;
int Led1 (String command)
//Particle.syncTime();
b=command;
Serial.println(CID);
b.toCharArray(CID,20);
EEPROM.put(0,CID);
return 1;
int Led2 (String command)
r=command;
r.toCharArray(CID,20);
EEPROM.put(21,CID);
return 1;
int Wtr(String command)
digitalWrite(D7,HIGH);
digitalWrite(D2,HIGH);
digitalWrite(D1,HIGH);Serial.println(con);
delay(w*1000);
digitalWrite(D7,LOW);
digitalWrite(D2,LOW);
digitalWrite(D1,LOW);
//previousMillis=millis();
//loop1();
//delay(3000); //delayloop1();
return 1;
void loop1()
//Serial.println ("Ron");
//currentMillis = millis()+1;
if( currentMillis- previousMillis>= t*60000){loop();}
currentMillis = millis();
//Serial.println (previousMillis);
//delay(1000);//Serial.println ("Kraus");
//Serial.println (millis());
delay(100);
loop1();
One possible issue is that when you run this the first time, the EEPROM will be all 0xff bytes (not 0x00 bytes), so when you assign String c to the contents you have an unterminated C string which could cause a SOS+1 fault.
Something like this would be safer:
String c;
EEPROM.get(0, CID);
CID[sizeof(CID) - 1] = 0;
if (CID[0] != 0xff) {
c = CID;
See also the EEPROM sample code.
