Boron reboot to change SIM
@GJMorrison ,
There is a way to do this but it requires external hardware (a watchdog timer) that can pull he Enable pin on the Boron low for 30 seconds. This may not be an option for you but, in case it is...
I have built such a carrier using the approach outlined int he Particle Application Note:
https://docs.particle.io/datasheets/app-notes/an023-watchdog-timers/
Here is the board, all open source:
Chip
