There is another thread proposing an ATTINY85 as the external low power device - it has 4 I/O. One could count Motion pulses, one could wake up the boron, on a count threshold or even a timer, via EN or via a mosfet to turn the Boron off between reporting cycles. The boron could turn itself off via a third Input I/O on the ATTINY85 (DONE pin). Sort of a WD and I/O pre processor combo that you could put into sleep mode and achieve much greater power economy
