I have code running on a Boron 2G/3G but after a while, the device starts randomly resetting. Noticed that when the first reset happens, more resets are bound to happen within seconds of each other.
I put in reset reason handling in here and the reason will print within 5 seconds of a reboot. Here is the code
#include "Particle.h"
#include "cn0357_app.h"
SYSTEM_THREAD(ENABLED);
uint32_t reset_reason = RESET_REASON_NONE;
void print_current_reset_reason( void );
void handle_reset( void );
Timer print_reset_reason(5000, print_current_reset_reason, true);
handle_reset();
Serial.begin(19200);
init_clo2_sensor();
print_reset_reason.start();
cn0357_churn();
System.enableFeature(FEATURE_RESET_INFO);
reset_reason = System.resetReason();
if ( reset_reason == RESET_REASON_PANIC)
System.enterSafeMode();
Serial.print("RESET REASON: "); Serial.println( reset_reason );
and here is the trace after the resets start coming in.
1/31/2021 12:11:03.667 DOCKLIGHT reports: General I/O error on COM4
General error while accessing the communication port
1/31/2021 12:11:04.402 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:10.308 [RX] - RESET REASON: 0
1/31/2021 12:11:12.376 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:19.013 [RX] - RESET REASON: 0
1/31/2021 12:11:22.487 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:23.021 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:29.136 [RX] - RESET REASON: 0
1/31/2021 12:11:33.040 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:39.681 [RX] - RESET REASON: 0
1/31/2021 12:11:41.934 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:42.276 DOCKLIGHT reports: General I/O error on COM4
1/31/2021 12:11:48.580 [RX] - RESET REASON: 0
I can’t find a pattern on when the resets happen.
Any insight on this?
