Boron Function not showing up in cloud
To avoid any confusion, the solution above is a workaround pending an upcoming holistic solution inclusive to Automatic Mode that we are currently anticipating will release in the upcoming week.
great to hear!
The fix should be released, rendering the workaround unnecessary. Please let me know if the issue persists - ideally, with a support ticket, wherein we could dig a little deeper.
I removed patch and updated to 1.5.1. The problem with functions showing up in the console/cli is fixed. However I am still having problems. I have gotten the signal strength up to 30% - best I can do without specialized equipment. The Boron pulses blue like it is connected and then I go to ping it and it is offline. It requires an unknown cocktail of power cycles, antenna re-plugs, and waiting to get it to ping and work with functions even when blinking blue. There is something going on in terms of cellular connection/back end/server side/TMobile that I don’t understand. I bring the device out in the yard where is gets 50-60% and all of my problems pretty much go away. I have not tested used single controlled variable, but it seems to pretty much work outside i.e. if the light is blue, I can ping it and the functions work.
