This is a repost of an earlier post I made but with new information and I have consolidated all the information. I've been struggling with this problem for a while and it is causing a big issue for my current project. Any help is appreciated!
I have a fleet of 30 boards. I have them all set up to sleep for most of the time but wake up from network messages, a GPIO pin, or a timeout of 15 minutes (to keep them all cloud connected). Only the GPIO pin wakeup method keeps the board awake for an extended period of time, the other wake up methods wake the board up for a very short amount of time and then puts them back to sleep. This is becoming a big issue for me because my boards are battery powered and these continuous wakeups are draining the batteries much faster than I had hoped.
This mostly works except I've noticed some of the boards will wake up from mysterious network messages very frequently. In fact, there seems to be a relationship between the amount of boards in my fleet that are powered on and the amount of boards that wake frequently from their sleep mode. I am trying to figure out the cause of the network message that is waking them up and determine if there is a way to prevent these messages from happening.
Here is a screenshot of my event logs during a short snippet of time when all 30 of my boards were powered on. The board names are omitted for project privacy but the first two letters were kept to indicate that this is happening to multiple different boards, not just one.
Here is the extended version of one of those captures:
"device":{
"network":{
"cellular":{
"radio_access_technology":"LTE"
"operator":"AT&T Wireless Inc."
"cell_global_identity":{
"mobile_country_code":310
"mobile_network_code":"410"
"location_area_code":21766
"cell_id":199695120
"signal":{
"at":"LTE Cat-M1"
"strength":76.66
"strength_units":"%"
"strengthv":-84
"strengthv_units":"dBm"
"strengthv_type":"RSRP"
"quality":37.5
"quality_units":"%"
"qualityv":-13.5
"qualityv_units":"dB"
"qualityv_type":"RSRQ"
"connection":{
"status":"connected"
"error":0
"disconnects":0
"attempts":1
"disconnect_reason":"unknown"
"cloud":{
"connection":{
"error":0
"attempts":1
"disconnects":0
"disconnect_reason":"none"
"coap":{
"transmit":17
"retransmit":4
"unack":0
"round_trip":296
"publish":{
"rate_limited":0
"power":{
"battery":{
"charge":{
"err":-210
"state":"disconnected"
"source":"USB adapter"
"system":{
"uptime":140
"memory":{
"used":71152
"total":165960
"service":{
"device":{
"status":"ok"
"cloud":{
"uptime":124
"publish":{
"sent":3
"coap":{
"round_trip":195
Here is a log of the SerialLogHandler(LOG_LEVEL_TRACE) of one of these boards during a wakeup:
0000140860 [comm.coap] TRACE: Sending CoAP message
0000140860 [comm.coap] TRACE: CON 0.00 size=4 token= id=17
0000140869 [ncp.at] TRACE: > AT+COPS=3,2
0000140870 [ncp.at] TRACE: < +CEREG: 5,"5506","0be71b10",7
0000140875 [ncp.at] TRACE: < OK
0000140881 [ncp.at] TRACE: > AT+COPS?
0000140885 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000140886 [ncp.at] TRACE: < OK
0000140888 [ncp.at] TRACE: > AT+UCGED?
0000141375 [ncp.at] TRACE: < +UCGED: 2
0000141376 [ncp.at] TRACE: < 6,4,310,410
0000141378 [ncp.at] TRACE: < 5110,12,50,50,5506,be71b10,181,cccb4d98,ff01,13,57,13,-1.43,3,255,255,56,7,-12,300,255,255,80
0000141389 [ncp.at] TRACE: < OK
0000141394 [ncp.at] TRACE: > AT+COPS=3,2
0000141398 [ncp.at] TRACE: < OK
0000141399 [ncp.at] TRACE: > AT+COPS?
0000141405 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000141406 [ncp.at] TRACE: < OK
0000141411 [ncp.at] TRACE: > AT+CEREG?
0000141416 [ncp.at] TRACE: < +CEREG: 2,5,"5506","0be71b10",7
0000141421 [ncp.at] TRACE: < OK
0000141422 [comm.coap] TRACE: Sending CoAP message
0000141427 [comm.coap] TRACE: CON POST /d?\x04 size=197 token=6b id=18
0000141435 [comm.coap] TRACE: Received CoAP message
0000141436 [comm.coap] TRACE: ACK 0.00 size=4 token= id=17
0000141639 [comm.coap] TRACE: Received CoAP message
0000141640 [comm.coap] TRACE: ACK 0.00 size=5 token=6b id=18
0000142371 [system.sleep] TRACE: Entering system_sleep_ext()
0000142371 [system.sleep] TRACE: Interface 3 is off already
For more context, here is my sleep config settings:
config.mode(SystemSleepMode::STOP)
.gpio(LIMIT_SWITCH, CHANGE)
.duration(15min)
.network(NETWORK_INTERFACE_CELLULAR);
Any clue here as to why my boards are receiving these messages? Any way to stop them? Any help is greatly greatly appreciated. Thank you!
