I tried different libraries posted in this forum for BMP085 but with nothing seems to be working. I am using Sparkfun BMP085 Breakout Board. Could someone help me to get it working. I am sure I am doing something wrong, could someone help me with circuit diagram and code. I am a beginner in this.
Serial.begin(9600); // start Core with Serial terminal Closed, then open serial terminal
while(!Serial.available()) SPARK_WLAN_Loop(); // wait for user to press ENTER in serial terminal
if (!bmp.begin()) {
Serial.println("Could not find a valid BMP085 sensor, check wiring!");
while(1) SPARK_WLAN_Loop(); // Die, with the possibility of reincarnation
(I just updated the Gist with this better code)
This pinout?
// SPARK CORE PINOUT ---------------------------------
// Connect VCC of the BMP085 sensor to 3.3* (NOT Vin!)
// Connect GND to GND
// Connect SCL to i2c clock - on Spark Core this is D1
// Connect SDA to i2c data - on Spark Core this is D0
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Are you seeing this error?
I tried from the beginning and still not working, one thing I found is that Spark Core hangs at bmp.begin(), I am trying another BMP085 and will update here.
Tried another BMP085 and is working. What is confusing is that the older one works well with Arduino and not with Spark Core, its very strange. Anyway I got it working with another one.
