BLE: cannot change MTU size at all
Hi guys,
First post here. Be gentle.
I am working with particle Argon SDK 3.3.0. I have read several other threads. When I connect to my BLE peripheral device from Argon acting as central, there is no way to change the MTU size.
The error is
0000533316 [hal.ble] TRACE: sd_ble_gattc_exchange_mtu_request() failed: 17
I can work with MTU sizes of more than 200 bytes with the same BLE peripheral when my central device is my laptop or a raspberry pi so the only one I cannot make it work is Argon.
Any hint how to solve this? Also tried calling functions from the HAL driver, no luck.
Maybe this is solved in SDK v4.0.0beta which I just saw available?
Please let me know your thoughts and have a nice day.
Hi and welcome to the forums!
The minimum MTU is 23 and the maximum appears to be 247.
Try calling:
int hal_ble_gatt_set_att_mtu(size_t att_mtu, void* reserved)
Pass nullptr for reserved. You shouldn’t need to add any include files.
I haven’t tested it, but this has worked for others in the past.
If I read the NRF BLE doc right, the stack is saying it is busy with error code 17.
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s132.api.v3.0.0/group___b_l_e___g_a_t_t_c___f_u_n_c_t_i_o_n_s.html?cp=4_7_3_9_2_2_2_6#ga269894b0415de8c4ae76343b74f6e655
