Best way to transfer large data from Photon
@jmosk, I used Quick’n Easy FTP Server light on windows:
http://www.pablosoftwaresolutions.com/html/quick__n_easy_ftp_server_lite.html
The Photon/Core code is a super easy adaptation of the Arduino code from the link I supplied:
   FTP passive client for IDE v1.0.1 and w5100/w5200
   Posted October 2012 by SurferTim
   Modified 6 June 2015 by SurferTim
#include "SD.h"
// comment out next line to write to SD from FTP server
#define FTPWRITE
// change to your server
IPAddress server( 192, 168, 0, 158 );  //Local network connected
TCPClient client;
TCPClient dclient;
char outBuf[128];
char outCount;
#define SD_CS	SS
byte doFTP();
byte eRcv();
void efail();
void readSD();
// change fileName to your file (8.3 format!)
char fileName[13] = "test.txt";
void setup()
  Serial.begin(9600);
  while(!Serial.available()) Particle.process();
  if(!SD.begin(SD_CS))
    Serial.println("SD init fail");
  Serial.println("Ready. Press f or r");
void loop()
  byte inChar;
  inChar = Serial.read();
  if(inChar == 'f')
    if(doFTP()) Serial.println("FTP OK");
    else Serial.println("FTP FAIL");
  if(inChar == 'r')
    readSD();
File fh;
byte doFTP()
#ifdef FTPWRITE
  fh = SD.open(fileName,FILE_READ);
#else
  SD.remove(fileName);
  fh = SD.open(fileName,FILE_WRITE);
#endif
  if(!fh)
    Serial.println("SD open fail");
    return 0;
#ifndef FTPWRITE
  if(!fh.seek(0))
    Serial.println("Rewind fail");
    fh.close();
    return 0;
#endif
  Serial.println("SD opened");
  if (client.connect(server,21)) {
    Serial.println("Command connected");
  else {
    fh.close();
    Serial.println("Command connection failed");
    return 0;
  if(!eRcv()) return 0;
  client.println("USER particle");
  client.println("PASS photon");
  client.println("SYST");
  client.println("Type I");
  client.println("PASV");
  char *tStr = strtok(outBuf,"(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL,"(,");
    array_pasv[i] = atoi(tStr);
    if(tStr == NULL)
      Serial.println("Bad PASV Answer");
  unsigned int hiPort,loPort;
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  Serial.print("Data port: ");
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(server,hiPort)) {
    Serial.println("Data connected");
  else {
    Serial.println("Data connection failed");
    client.stop();
    fh.close();
    return 0;
#ifdef FTPWRITE
  client.print("STOR ");
  client.println(fileName);
#else
  client.print("RETR ");
#endif
  if(!eRcv())
    dclient.stop();
    return 0;
#ifdef FTPWRITE
  Serial.println("Writing");
  byte clientBuf[64];
  int clientCount = 0;
  while(fh.available())
    clientBuf[clientCount] = fh.read();
    clientCount++;
    if(clientCount > 63)
      dclient.write(clientBuf,64);
      clientCount = 0;
  if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
  while(dclient.connected())
    while(dclient.available())
      char c = dclient.read();
      fh.write(c);
      Serial.write(c);
#endif
  dclient.stop();
  Serial.println("Data disconnected");
  client.println("QUIT");
  client.stop();
  Serial.println("Command disconnected");
  fh.close();
  Serial.println("SD closed");
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  while(!client.available()) Spark.process();
  respCode = client.peek();
  outCount = 0;
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if(outCount < 127)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  client.stop();
  fh.close();
void readSD()
  if(!fh)
    return;
    Serial.write(fh.read());
  fh.close();
Of course, you need to add an SD library to that. I used a hardware SPI connected microSD. :slight_smile:
