I’ve put the latest version with the primitive watchdog into a Gist. There is the spark cpp file, the python file that runs on a Raspberry Pi to control the Spark and a very short python script to plot out the daily audio measurements.
BeeMonitorGist
@CloudformDesign, if you are pulling together what you can find on UDP you may be interested in:
EnergyMonitorGist
which seems more reliable probably because it has a more robust WjFi link. I expect that the code uses functions that have been renamed in the latest version of the core software but I haven’t had to recompile so they are still the old version. To squeeze the data into the available space I converted the ADC data to 8 bits.
