Beehive Monitor, humidity, temp and weight
Hei
I wonder if any body can help me. I have tried, for a while now to make a beehive monitor with arduino but i have chanced to Particle electron. I want to measure temp, humidity and weight in the beehive. I,m using the DHT 22 and the HX711. But i,m struggling to find a code to use with the hardware. I want to publish the result to “Thingspeak”
Can somebody help me ?
the code i tried to use =
#include "ThingSpeak/ThingSpeak.h"
#include "Adafruit_DHT/Adafruit_DHT.h"
// Sensor type
#define DHTTYPE DHT22    	// DHT 22 (AM2302)
// DHT22 sensor pinout:
// Pin 1 (on the left): +3.3V
// Pin 2: output
// Pin 4 (on the right): GROUND
#define DHT_5V_PIN D1
#define DHT_SENSOR_PIN D2
#define DHT_GROUND_PIN D4
DHT dht(DHT_SENSOR_PIN, DHTTYPE);
/* Thingspeak */
TCPClient client;
unsigned long myChannelNumber = 89137;
const char * myWriteAPIKey = "3D23PQHQIJ3OZXNF";
    // Connect to ThingSpeak
    ThingSpeak.begin(client);
    // Give power to the sensor
    pinMode(DHT_5V_PIN, OUTPUT);
    pinMode(DHT_GROUND_PIN, OUTPUT);
    digitalWrite(DHT_5V_PIN, HIGH);
    digitalWrite(DHT_GROUND_PIN, LOW);
    // Wait for the sensor to stabilize
    delay(1000);
    // Initialize sensor
    dht.begin();
    // Read Sensor
    double temperature = dht.getTempCelcius();
    double humidity = dht.getHumidity();
    // Update the 2 ThingSpeak fields with the new data
    ThingSpeak.setField(1, (float)temperature);
    ThingSpeak.setField(2, (float)humidity);
    // Write the fields that you've set all at once.
    ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
    // Give time for the message to reach ThingSpeak
    delay(5000);
    // Sleep for 15 minutes to save battery
    System.sleep(SLEEP_MODE_DEEP, 15 * 60);
    // This will run because the system is sleeping
I have helped build a beehive monitor and I used these two libraries to talk to the sensors
https://build.particle.io/libs/HX711ADC/0.0.2
https://build.particle.io/libs/PietteTech_DHT/0.0.5
I have not used ThingSpeak, so I won’t be a lot of help.
But in order go get help, you may need to be a bit more precise what exactly your are struggling with.
You got some code for the DHT22, but does it work, what do you expect, what do you get, … ?
Hei, and thanks
I,m strugling to include the readings from the hx711. The code for the dht22 works with thingspeak.
My question is… what code is missing or what do i have to add to include the readings from the hx711 and Publishing this on thingspeak…
Have you had a look at the demo that comes with the library?
https://build.particle.io/libs/HX711ADC/0.0.2/tab/example/HX711Serial.ino
