In the schematics this pin is marked as /CHG which indicates active low which will be pulled high when there is a supply coming from VUSB.
Without VUSB (indicated by PWR) the 6k2 pull-down will enforce the low level.
So only the combination PWR && !CHG will provide the actual charging status.
