I feel like I have exhausted every resource online trying to find a routine to decode a Base64 encoded String. I need a method I can pass a String to and have it return something like an unsiged char[] or other form of byte array. Does anyone have anything?
What about this 10 second Google search?
Hi @ScruffR,
That decode method returns a string. I need to return an unsigned char array so I can get null bytes. That was the problem.
Here is my new working code:
void aes_client::base64_decode(const char *data, size_t input_length, size_t *output_length, unsigned char* outputData) {
if (decoding_table == NULL) build_decoding_table();
if (input_length % 4 != 0) return;
int inputLength = input_length / 4 * 3;
// *output_length = input_length / 4 * 3;
if (data[input_length - 1] == '=') (inputLength)--;
if (data[input_length - 2] == '=') (inputLength)--;
unsigned char t[(size_t)inputLength];
// unsigned char *decoded_data = t;
// if (decoded_data == NULL) return;
for (int i = 0, j = 0; i < input_length;) {
uint32_t sextet_a = data[i] == '=' ? 0 & i++ : decoding_table[data[i++]];
uint32_t sextet_b = data[i] == '=' ? 0 & i++ : decoding_table[data[i++]];
uint32_t sextet_c = data[i] == '=' ? 0 & i++ : decoding_table[data[i++]];
uint32_t sextet_d = data[i] == '=' ? 0 & i++ : decoding_table[data[i++]];
uint32_t triple = (sextet_a << 3 * 6)
+ (sextet_b << 2 * 6)
+ (sextet_c << 1 * 6)
+ (sextet_d << 0 * 6);
if (j < inputLength) t[j++] = (triple >> 2 * 8) & 0xFF;
if (j < inputLength) t[j++] = (triple >> 1 * 8) & 0xFF;
if (j < inputLength) t[j++] = (triple >> 0 * 8) & 0xFF;
memcpy(outputData, t, inputLength);
