AWS IoT Install Certificate
Hi:
I have two questions:
  1. I’m trying the AWS IoT services. Anyone knows if it is possible in particle photon product to run TLS MQTT?. I used the MQTT library but not over TLS.
  2. In case we use HTTPS, is it possible to install a 509 certificate in photon? (Amazon certificate). How?, perhaps using the particle CLI?
I read someone suggest to consume AWS using a web hook, and in photon using the instruction particle.publish. It uses the Particle cloud IoT to pass data to Amazon cloud. But I think this is not optimal.
Any idea?
thank you in advance,
Marcelo Rocha
