@ScruffR - you’re a gentleman and a scholar.
I got it working, and it also resolved my earlier hard fault issues (SOS & 1 red blink).
The following is the code I’ve used successfully. Any ideas for improvements are most welcome!
#include "application.h"
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean sensor_string_complete = false; //have we received all the data from the Atlas Scientific product
float pH; //used to hold a floating point number that is the pH
int oldTime = 0;
void setup() { //set up the hardware
Serial.begin(9600); //set baud rate for the hardware serial port_0 to 9600
Serial1.begin(9600); //set baud rate for the software serial port to 9600
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
Serial.println('loop begin');
Serial1.print('r');
Serial1.print('\r');
delay(100);
oldTime = millis();
while(sensor_string_complete == false && millis()-oldTime < 5000) {
while(Serial1.available()) { //if we see that the Atlas Scientific product has sent a character
char inchar = (char)Serial1.read(); //get the char we just received
sensorstring += inchar; //add the char to the var called sensorstring
if (inchar == '\r') { //if the incoming character is a <CR>
sensor_string_complete = true; //set the flag
if (sensor_string_complete == true) { //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(sensorstring);
if (isdigit(sensorstring[0])) { //if the first character in the string is a digit
pH = sensorstring.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
if (pH >= 7.0) { //if the pH is greater than or equal to 7.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
if (pH <= 6.999) { //if the pH is less than or equal to 6.999
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
sensorstring = ""; //clear the string
sensor_string_complete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
delay(1000);
Additionally, I’ve tested that the code works on both Photons and Electrons.
