This seems like the simplest use of an Electron but I can’t seem to find the answer.
I want the Electron to close a relay (bit goes high), wait for 2 minutes and have that bit go low. This should be triggered with a POST like:
curl https://api.particle.io/v1/devices/12341234123412341234/backsprink/ -d access_token=brokenpokentoken -d args=zone3
Problem is: as I am doing it I get timeouts on the client side, since my code waits too long to report it is done. Really I want the electron to report back right away “ok” that it is starting the cycle and have the cycle just run asynchronously. Bonus would be if I can make another call while the timer was running and have it interrupted.
my code is like:
int led1 = D0;
int led2 = D1;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
Particle.function("backsprink", backSprink);
int backSprink(String command) {
if(command == "zone1") {
digitalWrite(led1, HIGH);
delay(120000);
digitalWrite(led1, LOW);
return(0);
Any help would be much appreciated!!
