Thanks for the tag @kennethlimcp! Hiya @johncohn, if that’s having issues it’s probably my fault- I put together the library. gpsOn() shouldn’t cause issues for the accel, but you never know. Could you paste in the rest of your code?
You can also check out @Dave’s awesome library- https://github.com/dmiddlecamp/fancy-asset-tracker
Here’s what’s in gpsOn(), for reference:
void AssetTracker::gpsOn(){
// Power to the GPS is controlled by a FET connected to D6
pinMode(D6,OUTPUT);
digitalWrite(D6,LOW);
gps.begin(9600);
gps.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
delay(500);
// Default is 1 Hz update rate
gps.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
delay(500);
gps.sendCommand(PGCMD_NOANTENNA);
delay(500);
