Arm-none-eabi-g++: nano.specs: No such file or directory
Just tried to build new (July 2nd) bug fix source:
https://github.com/spark/core-firmware/tree/bug-fix/ota-flash-reliability
It made it most of the way through but finally gave this error:
arm-none-eabi-g++: nano.specs: No such file or directory
mingw32-make: *** [core-firmware.elf] Error 1
I have been able to build past source no problem.
I searched for a file called nano.specs in my file system, and there are several of them in the arm-none-eabi/lib folders.
The new makefile has a couple of extra lines but apparently my toolchain doesn’t know what to do with them:
LDFLAGS += --specs=nano.specs -lc -lnosys
LDFLAGS += -u _printf_float
I am using this compiler (running on XP):
https://launchpadlibrarian.net/170926686/gcc-arm-none-eabi-4_8-2014q1-20140314-win32.zip
Not sure about the compiler link that you mentioned above.
Try this link instead and make sure the %PATH% env. variable is updated:
https://launchpad.net/gcc-arm-embedded/4.8/4.8-2014-q2-update/+download/gcc-arm-none-eabi-4_8-2014q2-20140609-win32.exe
Thanks Satishgn. You’ve been a tremendous help in the connectivity issues I’ve been having, and with this problem as well.
Turns out I have several different arm toolchains scattered in my filesystem. Installing the one you mentioned did the trick as long as I run it from the command window that is provided with it in the install.
