Argon / Boron / Xenon bench test/demo of primary functionality
I put together this bench example of how to use the primary communication functions of the Particle Argon / Boron / Xenon device. It demonstrates how each device can communicate privately within the Mesh network, and with the Particle Cloud. Analog data from an Argon and a Xenon are published to the Particle Cloud. When a pushbutton is pressed on the Argon, it is published to the Mesh network and the Xenon reacts by blinking a LED. When a pushbutton is pushed on the Argon, the event is published to the Particle Cloud, and the Xenon blinks in response, and you can see the event in the Particle Cloud console.
http://www.savvysolutions.info/savvymicrocontrollersolutions/particle.php?topic=particle-bench-test-demo
I need help with Boron code. Are you interested?
John
954 292 6194
Sloopjohnb@bellsouth.net
