Hello all,
i am using same code for both Argon and Baron, and i use function fuel.getSoC() to measure the battery level, on Baron working good i got value of 91% but in Argon i got value of -1. i use exact same code for both. any idea please?
Thank you
The Argon lacks a fuel gauge and therefore won’t return a percentage.
You need to read the battery voltage using the following: https://docs.particle.io/reference/device-os/firmware/#battery-voltage
great, thanks @no1089
