Arduino > photon library
Hi there I’m new to particle.
I am trying to convert a library that’s for the Arduino to be used by the photon.
In the library it includes the Arduino ethernet and or wifi library, obviously the photon does not use/require this so how would I replace with a photon equivalent?
#if defined(PubNub_Ethernet)
#include <Ethernet.h>
#define PubNub_BASE_CLIENT EthernetClient
What should the PubNub_BASE_CLIENT be equal to?
You won’t need them :wink:
Sure I Kinda get that but PubNub_BASE_CLIENT is referenced throughout the current library so surely I need to point that at something on the photon end?
Hi @lindstrom1989
There is no Particle class that is a direct substitute for EthernetClient. The TCPClient class or the TCPServer class are probably what you want to use but I would look at each method call and see if it makes sense.
Ok I’ll give it a try, where does that class come from? is it an external library? thanks
Hi @lindstrom1989
Both the TCPClient and TCPServer classes are built-in and you don’t need any include in the webIDE. In a C++ library you should do #include "application.h" to get them. This include could change names in the future. You can use various #ifdef macros to make your library more portable or you can make a Particle-specific version.
