I’m trying to make a spark core controlled midi device, I have all the hardware together, I’m not sure how to use the arduino midi library with my code, there is no library in the online IDE for midi. When I try to get the code from github it says its incompatible?
I moved a post to an existing topic: Simple MIDI input/output library (via GPIO pins)?
Try the search function next time, it really does work
