Hello
I have tried the watchdog example as it is stated here:
https://docs.particle.io/reference/device-os/firmware/photon/#sts=Application%20Watchdog
Instead of success message I get this:
“request for member ‘checkin’ in ‘wd’, which is of pointer type ‘ApplicationWatchdog*’ (maybe you meant to use ‘->’ ?)”
Any ideas why this happens?
ApplicationWatchdog *wd;
// Start watchdog. Reset the system after 60 seconds if
// the application is unresponsive.
wd = new ApplicationWatchdog(60000, System.reset, 1536);
while (some_long_process_within_loop) {
wd.checkin(); // resets the AWDT count
// AWDT count reset automatically after loop() ends
