Anyone got wired ethernet working?
what is so different in deviceos that the argon connects over wired ethernet so very fast?! (8 seconds about). if the p2 connects it takes way longer
also noticed argon boot so much faster compared to p2. p2 has seconds delay before starting user application
The boot time difference is just how the MCU boots. The Nordic nRF52 has a very fast boot time, the Realtek RTL872x is slower.
I'm not sure why the Ethernet connect speeds should be significantly different, however. Both use the same WizNET W5500 driver and IP stack (LwIP). They're built out of the same source code, though at the lowest layer (SPI) they're obviously different because of the different MCU SDKs and hardware.
boot time: understood
ethernet: argon consistently connects in less than 10s. photon2 almost never... same hardware (where the argon or photon2 plugs in), same application, same network
hope you have enough to debug this. let me know if i can help!
thanks
frank
@boddeke I just spoke to engineering - they are investigating, but it's likely to be a week or two before I have answers.
hi chris/@no1089, were you able to replicate the problem? is there anything i can do to help? hope they figure it out soon as we are in the process of going into production. thanks, frank
@marekparticle @rickkas7 @no1089 If you need another set of logs then I can also pitch in. The logs and observations that Frank has made are exactly the same as I am seeing. At the moment Ethernet support on the P2 is a key feature justifying migration from Photon for our first product to be redeveloped around the P2 - very much looking forward to hearing progress on this issue. Will
@marekparticle @rickkas7 @no1089 one more observation: we have a simple logger implementation that spits out the log lines over udp to a server. for wifi it works very well. for ethernet, assuming it connected, not so much: to debug an (other) issue we have 700 short log lines (e.g. "[0] 32 50 '2'") to check a buffer with chars (see below). when on wifi we see all lines. when on ethernet we see mostly none of the lines... maybe a hint?
for(int i=0;i<700;i++) {
        Watchdog.refresh();
        if(((int)t[i] >= 0x20) && ((int)t[i] <= 0x7e)) {
            Log.info("[%d] %x %d '%c'",i,(int)t[i],(int)t[i],t[i]);
        } else {
            Log.info("[%d] %x %d",i,(int)t[i],(int)t[i]);
        Particle.process();
Hi folks, our Engineering team is actively engaged with this report this sprint. Expect an update soon.
@marekparticle @rickkas7 @no1089 any news? did see 5.5.0-rc.1 - something for us to try?
There are no changes in 5.5.0-rc.1 related to Ethernet.
it has been 20 days... @marekparticle @rickkas7 @no1089 any news?
And no changes in 5.5.0 judging by the change log. Any thoughts from the Engineering team?
It's being investigated now. The investigation did not start until after 5.5.0 was released.
Hi Folks!
While we are working on finding the root cause to this issue, I wanted to give you a potential workaround. The issue seems to be something making the connection process ultimately slower than normal. So if you are using the EthernetCellularRK library, you will want to change the default Ethernet connection timeout to be larger than 30s.
#include "Particle.h"
#include "EthernetCellularRK.h"
// Optional logging
SerialLogHandler LogHandler(LOG_LEVEL_TRACE);
// SYSTEM_THREAD(ENABLED) and SYSTEM_MODE(SEMI_AUTOMATIC) are required
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
    // Wait for a USB serial connection for up to 15 seconds
    // Only used during testing so all of the log messages can be seen
    waitFor(Serial.isConnected, 15000); delay(2000);
    // You must add this to your setup() function
    EthernetCellular::instance().setup();
    // TEMP WORKAROUND: Increase default timeout from 30s to 3mins
    EthernetCellular::instance().withEthernetConnectTimeout(std::chrono::milliseconds(3min));
    // You must add this to your loop() function
    EthernetCellular::instance().loop();
hi @BDub, that is all nice and stuff but of course we already tried that. one of the 2 types LAN we test with will not connect whatever the timeout. see all logging we gathered for you
@boddeke rest assured that we are still fully engaged with the issue above. I can't offer a timeline at the moment, but the issue is complex and will still take a few weeks. However, it is actively the subject of ongoing Engineering work.
Hi @boddeke ,
Thanks for the feedback. I looked at one of the logs you posted for P2 above and it seems like the timeout is still set to 30s. See this log message at 34.2s.
Depending on your application firmware, there might be other complications though... so I can't say for sure the proposed workaround will fix things for you. If you want to try the example app I posted above and post those logs, I'd be happy to collect it for our internal investigation on the root cause. Thanks!
Not a silver bullet but it does appear to be a workaround for me. Running a test to see if there are drop-outs once connected to ethernet and how frequent.
it does seem to help! i thought i tested this (allow long connection times) but i guess not or without other complicating factors. i did find an issue where if ethernet ready fails in 5s (the timeout) it would not do ethernet.disconnect() before connecting again and it would not really retry just keep on connecting (and never did)
i have run a test overnight: connect to ethernet and once connected restart the system. it connects in anywhere from 10s to 1500s (ready timeout 5s, connect timeout 3m). see below.
but i found it this morning "solid cyan" and not logging anything anymore. see P2 stuck at (solid) cyan
connection times (selected log lines):
0000022591 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000016783 [app] INFO: Ethernet cloud connected in 14 s (link: 2 s), (re)connected in 16 s
0000365922 [app] INFO: Ethernet cloud connected in 182 s (link: 2 s), (re)connected in 365 s
0000010184 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000013220 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 13 s
0000042850 [app] INFO: Ethernet cloud connected in 40 s (link: 1 s), (re)connected in 42 s
0000038573 [app] INFO: Ethernet cloud connected in 36 s (link: 1 s), (re)connected in 38 s
0000014190 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 14 s
0000011707 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000031201 [app] INFO: Ethernet cloud connected in 29 s (link: 0 s), (re)connected in 31 s
0000069650 [app] INFO: Ethernet cloud connected in 67 s (link: 1 s), (re)connected in 69 s
0000041892 [app] INFO: Ethernet cloud connected in 40 s (link: 2 s), (re)connected in 41 s
0000015351 [app] INFO: Ethernet cloud connected in 13 s (link: 1 s), (re)connected in 15 s
0000016562 [app] INFO: Ethernet cloud connected in 14 s (link: 4 s), (re)connected in 16 s
0000057385 [app] INFO: Ethernet cloud connected in 55 s (link: 1 s), (re)connected in 57 s
0000022888 [app] INFO: Ethernet cloud connected in 15 s (link: 1 s), (re)connected in 22 s
0000015689 [app] INFO: Ethernet cloud connected in 13 s (link: 1 s), (re)connected in 15 s
0000024299 [app] INFO: Ethernet cloud connected in 22 s (link: 1 s), (re)connected in 24 s
0000011416 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000022028 [app] INFO: Ethernet cloud connected in 20 s (link: 2 s), (re)connected in 22 s
0000013416 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000011444 [app] INFO: Ethernet cloud connected in 9 s (link: 0 s), (re)connected in 11 s
0000011555 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000436433 [app] INFO: Ethernet cloud connected in 62 s (link: 0 s), (re)connected in 436 s
0000013064 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000384327 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 384 s
0000236289 [app] INFO: Ethernet cloud connected in 46 s (link: 4 s), (re)connected in 236 s
0000048130 [app] INFO: Ethernet cloud connected in 46 s (link: 1 s), (re)connected in 48 s
0000166700 [app] INFO: Ethernet cloud connected in 164 s (link: 0 s), (re)connected in 166 s
0000031676 [app] INFO: Ethernet cloud connected in 29 s (link: 0 s), (re)connected in 31 s
0000010844 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000017418 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 17 s
0000014292 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 14 s
0000011725 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000011640 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000007606 [app] INFO: Ethernet cloud connected in 5 s (link: 1 s), (re)connected in 7 s
0000241363 [app] INFO: Ethernet cloud connected in 57 s (link: 0 s), (re)connected in 241 s
0000010981 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 10 s
0000055856 [app] INFO: Ethernet cloud connected in 54 s (link: 1 s), (re)connected in 55 s
0000011703 [app] INFO: Ethernet cloud connected s), (re)connected in 11 s
0000009060 [app] INFO: Ethernet cloud connected in 7 s (link: 0 s), (re)connected in 9 s
0000011459 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000007965 [app] INFO: Ethernet cloud connected in 6 s (link: 1 s), (re)connected in 7 s
0000041758 [app] INFO: Ethernet cloud connected in 39 s (link: 1 s), (re)connected in 41 s
0000064667 [app] INFO: Ethernet cloud connected in 62 s (link: 1 s), (re)connected in 64 s
0000016221 [app] INFO: Ethernet cloud connected in 14 s (link: 2 s), (re)connected in 16 s
0000012845 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 12 s
0000045333 [app] INFO: Ethernet cloud connected in 43 s (link: 1 s), (re)connected in 45 s
0000120731 [app] INFO: Ethernet cloud connected in 113 s (link: 2 s), (re)connected in 120 s
0000015221 [app] INFO: Ethernet cloud connected in 13 s (link: 2 s), (re)connected in 15 s
0000019922 [app] INFO: Ethernet cloud connected in 18 s (link: 1 s), (re)connected in 19 s
0000024218 [app] INFO: Ethernet cloud connected in 22 s (link: 1 s), (re)connected in 24 s
0000018000 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 18 s
0000022093 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000017431 [app] INFO: Ethernet cloud connected in 15 s (link: 1 s), (re)connected in 17 s
0000019513 [system] INFO: Cloud con0000019524 [app] INFO: Ethernet cloud connected in 12 s (link: 4 s), (re)connected in 19 s
0000047773 [app] INFO: Ethernet cloud connected in 45 s (link: 2 s), (re)connected in 47 s
0000038900 [app] INFO: Ethernet cloud connected in 37 s (link: 1 s), (re)connected in 38 s
0000011510 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000254297 [app] INFO: Ethernet cloud connected in 70 s (link: 0 s), (re)connected in 254 s
0000014124 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 14 s
0000018275 [app] INFO: Ethernet cloud connected in 16 s (link: 1 s), (re)connected in 18 s
0000042924 [app] INFO: Ethernet cloud connected in 41 s (link: 1 s), (re)connected in 42 s
0000020197 [app] INFO: Ethernet cloud connected in 18 s (link: 1 s), (re)connected in 20 s
0000341354 [app] INFO: Ethernet cloud connected in 158 s (link: 0 s), (re)connected in 341 s
0000240005 [app] INFO: Ethernet cloud connected in 55 s (link: 0 s), (re)connected in 240 s
0000236656 [app] INFO: Ethernet cloud connected in 52 s (link: 0 s), (re)connected in 236 s
0000012371 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000008348 [app] INFO: Ethernet cloud connected in 6 s (link: 1 s), (re)connected in 8 s
0000011671 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000013515 [app] INFO: Ethernet cloud connected in 11 s (link: 3 s), (re)connected in 13 s
0000099887 [app] INFO: Ethernet cloud connected in 98 s (link: 1 s), (re)connected in 99 s
0000051491 [app] INFO: Ethernet cloud connected in 49 s (link: 2 s), (re)connected in 51 s
0000011419 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000021219 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 21 s
0000025188 [app] INFO: Ethernet cloud connected in 23 s (link: 4 s), (re)connected in 25 s
0000012443 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000037892 [app] INFO: Ethernet cloud connected in 36 s (link: 1 s), (re)connected in 37 s
0000013649 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 13 s
0000010054 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000009057 [app] INFO: Ethernet cloud connected in 7 s (link: 1 s), (re)connected in 9 s
0000011566 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000010706 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000022251 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000011140 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000047167 [app] INFO: Ethernet cloud connected in 45 s (link: 1 s), (re)connected in 47 s
0000219714 [app] INFO: Ethernet cloud connected in 35 s (link: 0 s), (re)connected in 219 s
0000041747 [app] INFO: Ethernet cloud connected in 39 s (link: 0 s), (re)connected in 41 s
0000014117 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 14 s
0000009674 [app] INFO: Ethernet cloud connected in 7 s (link: 1 s), (re)connected in 9 s
0000025008 [app] INFO: Ethernet cloud connected in 23 s (link: 2 s), (re)connected in 25 s
0000194661 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 194 s
0000048591 [app] INFO: Ethernet cloud connected in 46 s (link: 2 s), (re)connected in 48 s
0000025652 [app] INFO: Ethernet cloud connected in 23 s (link: 2 s), (re)connected in 25 s
0000023717 [app] INFO: Ethernet cloud connected in 21 s (link: 1 s), (re)connected in 23 s
0000018316 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 18 s
0000420410 [app] INFO: Ethernet cloud connected in 42 s (link: 0 s), (re)connected in 420 s
0000811367 [app] INFO: Ethernet cloud connected in 37 s (link: 1 s), (re)connected in 811 s
0000011227 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000011277 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000022830 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000138509 [app] INFO: Ethernet cloud connected in 136 s (link: 1 s), (re)connected in 138 s
0000015418 [app] INFO: Ethernet cloud connected in 13 s (link: 2 s), (re)connected in 15 s
0000009487 [app] INFO: Ethernet cloud connected in 7 s (link: 1 s), (re)connected in 9 s
0000435941 [app] INFO: Ethernet cloud connected in 21 s (link: 3 s), (re)connected in 435 s
0000021529 [app] INFO: Ethernet cloud connected in 19 s (link: 0 s), (re)connected in 21 s
0000264528 [app] INFO: Ethernet cloud connected in 81 s (link: 0 s), (re)connected in 264 s
0000016874 [app] INFO: Ethernet cloud connected in 15 s (link: 1 s), (re)connected in 16 s
0000010378 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000013622 [app] INFO: Ethernet cloud connected in 11 s (link: 0 s), (re)connected in 13 s
0000207660 [app] INFO: Ethernet cloud connected in 24 s (link: 2 s), (re)connected in 207 s
0000027077 [app] INFO: Ethernet cloud connected in 25 s (link: 2 s), (re)connected in 27 s
0000017448 [app] INFO: Ethernet cloud connected in 15 s (link: 1 s), (re)connected in 17 s
0000018502 [app] INFO: Ethernet cloud connected in 11 s (link: 3 s), (re)connected in 18 s
0000011171 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000011179 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000012207 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000025724 [app] INFO: Ethernet cloud connected in 23 s (link: 0 s), (re)connected in 25 s
0000023989 [app] INFO: Ethernet cloud connected in 22 s (link: 1 s), (re)connected in 23 s
0000013529 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000012273 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000025061 [app] INFO: Ethernet cloud connected in 23 s (link: 1 s), (re)connected in 25 s
0000331851 [app] INFO: Ethernet cloud connected in 148 s (link: 0 s), (re)connected in 331 s
0000107814 [app] INFO: Ethernet cloud connected in 105 s (link: 1 s), (re)connected in 107 s
0000011782 [app] INFO: Ethernet cloud connected in 9 s (link: 2 s), (re)connected in 11 s
0000824340 [app] INFO: Ethernet cloud connected in 12 s (link: 4 s), (re)connected in 824 s
0000024946 [app] INFO: Ethernet cloud connected in 23 s (link: 1 s), (re)connected in 24 s
0000012757 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000015578 [app] INFO: Ethernet cloud connected in 13 s (link: 1 s), (re)connected in 15 s
0000018887 [app] INFO: Ethernet cloud connected in 17 s (link: 1 s), (re)connected in 18 s
0000383877 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 383 s
0000239700 [app] INFO: Ethernet cloud connected in 50 s (link: 1 s), (re)connected in 239 s
0000035160 [app] INFO: Ethernet cloud connected in 33 s (link: 4 s), (re)connected in 35 s
0000018096 [app] INFO: Ethernet cloud connected in 16 s (link: 1 s), (re)connected in 18 s
0000048000 [app] INFO: Ethernet cloud connected in 46 s (link: 3 s), (re)connected in 48 s
0000028473 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 28 s
0000028805 [app] INFO: Ethernet cloud connected in 26 s (link: 3 s), (re)connected in 28 s
0000032941 [app] INFO: Ethernet cloud connected in 9 s (link: 2 s), (re)connected in 32 s
0000047194 [app] INFO: Ethernet cloud connected in 45 s (link: 1 s), (re)connected in 47 s
0000586454 [app] INFO: Ethernet cloud connected in 28 s (link: 1 s), (re)connected in 586 s
0000026047 [app] INFO: Ethernet cloud connected in 24 s (link: 2 s), (re)connected in 26 s
0000012397 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000043233 [app] INFO: Ethernet cloud connected in 41 s (link: 0 s), (re)connected in 43 s
0000023563 [app] INFO: Ethernet cloud connected in 21 s (link: 1 s), (re)connected in 23 s
0000196321 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 196 s
0000338526 [app] INFO: Ethernet cloud connected in 149 s (link: 2 s), (re)connected in 338 s
0001480810 [app] INFO: Ethernet cloud connected in 122 s (link: 3 s), (re)connected in 1480 s
0000037717 [app] INFO: Ethernet cloud connected in 35 s (link: 2 s), (re)connected in 37 s
0000027788 [app] INFO: Ethernet cloud connected in 20 s (link: 2 s), (re)connected in 27 s
0000565218 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 565 s
0000017974 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 17 s
0000015680 [app] INFO: Ethernet cloud connected in 13 s (link: 1 s), (re)connected in 15 s
0000017179 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 17 s
0000027665 [app] INFO: Ethernet cloud connected in 25 s (link: 4 s), (re)connected in 27 s
0000013539 [app] INFO: Ethernet cloud connected in 6 s (link: 1 s), (re)connected in 13 s
0000010793 [app] INFO: Ethernet cloud connected in 8 s (link: 1 s), (re)connected in 10 s
0000422853 [app] INFO: Ethernet cloud connected in 42 s (link: 2 s), (re)connected in 422 s
0000596565 [app] INFO: Ethernet cloud connected in 16 s (link: 1 s), (re)connected in 596 s
0000011217 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000097303 [app] INFO: Ethernet cloud connected in 95 s (link: 2 s), (re)connected in 97 s
0000029102 [app] INFO: Ethernet cloud connected in 21 s (link: 2 s), (re)connected in 29 s
0000046751 [app] INFO: Ethernet cloud connected in 44 s (link: 1 s), (re)connected in 46 s
0000011264 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000109179 [app] INFO: Ethernet cloud connected in 107 s (link: 1 s), (re)connected in 109 s
0000036522 [app] INFO: Ethernet cloud connected in 34 s (link: 3 s), (re)connected in 36 s
0000431102 [app] INFO: Ethernet cloud connected in 46 s (link: 4 s), (re)connected in 431 s
0000021229 [app] INFO: Ethernet cloud connected in 19 s (link: 0 s), (re)connected in 21 s
0000013130 [app] INFO: Ethernet cloud connected in 11 s (link: 4 s), (re)connected in 13 s
0000180854 [app] INFO: Ethernet cloud connected in 179 s (link: 1 s), (re)connected in 180 s
0000016172 [app] INFO: Ethernet cloud connected in 14 s (link: 1 s), (re)connected in 16 s
0000025110 [app] INFO: Ethernet cloud connected in 23 s (link: 2 s), (re)connected in 25 s
0000008734 [app] INFO: Ethernet cloud connected in 6 s (link: 1 s), (re)connected in 8 s
0000012613 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000013154 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000043985 [app] INFO: Ethernet cloud connected in 42 s (link: 1 s), (re)connected in 43 s
0000021396 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 21 s
0000333422 [app] INFO: Ethernet cloud connected in 149 s (link: 2 s), (re)connected in 333 s
0000032715 [app] INFO: Ethernet cloud connected in 25 s (link: 2 s), (re)connected in 32 s
0000211373 [app] INFO: Ethernet cloud connected in 22 s (link: 4 s), (re)connected in 211 s
0000058104 [app] INFO: Ethernet cloud connected in 56 s (link: 2 s), (re)connected in 58 s
0000021451 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 21 s
0000121904 [app] INFO: Ethernet cloud connected in 120 s (link: 1 s), (re)connected in 121 s
0000174847 [app] INFO: Ethernet cloud connected in 167 s (link: 2 s), (re)connected in 174 s
0000030277 [app] INFO: Ethernet cloud connected in 28 s (link: 2 s), (re)connected in 30 s
0000227568 [app] INFO: Ethernet cloud connected in 43 s (link: 3 s), (re)connected in 227 s
0000013280 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000011542 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000229678 [app] INFO: Ethernet cloud connected in 45 s (link: 3 s), (re)connected in 229 s
0000012934 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 12 s
0000021013 [app] INFO: Ethernet cloud connected in 13 s (link: 2 s), (re)connected in 21 s
0000016414 [app] INFO: Ethernet cloud connected in 14 s (link: 1 s), (re)connected in 16 s
0000012711 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000581569 [app] INFO: Ethernet cloud connected in 25 s (link: 0 s), (re)connected in 581 s
0000012418 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000018092 [app] INFO: Ethernet cloud connected in 16 s (link: 3 s), (re)connected in 18 s
0000014673 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 14 s
0000011989 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 11 s
0000014896 [app] INFO: Ethernet cloud connected in 13 s (link: 1 s), (re)connected in 14 s
0000487989 [app] INFO: Ethernet cloud connected in 117 s (link: 2 s), (re)connected in 487 s
0000116158 [app] INFO: Ethernet cloud connected in 114 s (link: 1 s), (re)connected in 116 s
0000106746 [app] INFO: Ethernet cloud connected in 104 s (link: 3 s), (re)connected in 106 s
0000012723 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 12 s
0000045006 [app] INFO: Ethernet cloud connected in 43 s (link: 1 s), (re)connected in 45 s
0000013201 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000026047 [app] INFO: Ethernet cloud connected in 24 s (link: 1 s), (re)connected in 26 s
0000012752 [app] INFO: Ethernet cloud connected in 10 s (link: 3 s), (re)connected in 12 s
0000023852 [app] INFO: Ethernet cloud connected in 22 s (link: 2 s), (re)connected in 23 s
0000009058 [app] INFO: Ethernet cloud connected in 7 s (link: 0 s), (re)connected in 9 s
0000011788 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000013971 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 13 s
0000039760 [app] INFO: Ethernet cloud connected in 37 s (link: 0 s), (re)connected in 39 s
0000028035 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 28 s
0000010872 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 10 s
0000011257 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000694991 [app] INFO: Ethernet cloud connected in 132 s (link: 1 s), (re)connected in 694 s
0000030018 [app] INFO: Ethernet cloud connected in 28 s (link: 1 s), (re)connected in 30 s
0000011747 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000011136 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000019752 [app] INFO: Ethernet cloud connected i(link: 2 s), (re)connected in 19 s
0000013728 [app] INFO: Ethernet cloud connected in 6 s (link: 1 s), (re)connected in 13 s
0000177252 [app] INFO: Ethernet cloud connected in 175 s (link: 2 s), (re)connected in 177 s
0000033844 [app] INFO: Ethernet cloud connected in 26 s (link: 2 s), (re)connected in 33 s
0000040453 [app] INFO: Ethernet cloud connected in 38 s (link: 0 s), (re)connected in 40 s
0000016117 [app] INFO: Ethernet cloud connected in 14 s (link: 1 s), (re)connected in 16 s
0000044771 [app] INFO: Ethernet cloud connected in 42 s (link: 1 s), (re)connected in 44 s
0000037611 [app] INFO: Ethernet cloud connected in 35 s (link: 1 s), (re)connected in 37 s
0000201010 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 201 s
0000029293 [app] INFO: Ethernet cloud connected in 21 s (link: 4 s), (re)connected in 29 s
0000016128 [app] INFO: Ethernet cloud connected in 14 s (link: 2 s), (re)connected in 16 s
0000198927 [app] INFO: Ethernet cloud connected in 15 s (link: 0 s), (re)connected in 198 s
0000036294 [app] INFO: Ethernet cloud connected in 34 s (link: 1 s), (re)connected in 36 s
0000014836 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 14 s
0000012598 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000029586 [app] INFO: Ethernet cloud connected in 27 s (link: 1 s), (re)connected in 29 s
0000025145 [app] INFO: Ethernet cloud connected in 23 s (link: 1 s), (re)connected in 25 s
0000116686 [app] INFO: Ethernet cloud connected in 109 s (link: 2 s), (re)connected in 116 s
0000014159 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 14 s
0000036801 [app] INFO: Ethernet cloud connected in 19 s (link: 2 s), (re)connected in 36 s
0000011350 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000015856 [app] INFO: Ethernet cloud connected in 14 s (link: 4 s), (re)connected in 15 s
0000041934 [app] INFO: Ethernet cloud connected in 40 s (link: 1 s), (re)connected in 41 s
0000021137 [app] INFO: Ethernet cloud connected in 19 s (link: 2 s), (re)connected in 21 s
0000011825 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000012095 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000010906 [app] INFO: Ethernet cloud connected in 9 s (link: 0 s), (re)connected in 10 s
0000236063 [app] INFO: Ethernet cloud connected in 52 s (link: 2 s), (re)connected in 236 s
0000027584 [app] INFO: Ethernet cloud connected in 25 s (link: 1 s), (re)connected in 27 s
0000049020 [app] INFO: Ethernet cloud connected in 47 s (link: 1 s), (re)connected in 49 s
0000030771 [app] INFO: Ethernet cloud connected in 28 s (link: 1 s), (re)connected in 30 s
0000021210 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 21 s
0000018738 [app] INFO: Ethernet cloud connected in 16 s (link: 1 s), (re)connected in 18 s
0000022773 [app] INFO: Ethernet cloud connected in 15 s (link: 3 s), (re)connected in 22 s
0000008850 [app] INFO: Ethernet cloud connected in 6 s (link: 0 s), (re)connected in 8 s
0000043510 [app] INFO: Ethernet cloud connected in 25 s (link: 1 s), (re)connected in 43 s
0000013587 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000019298 [app] INFO: Ethernet cloud connected in 12 s (link: 2 s), (re)connected in 19 s
0000155380 [app] INFO: Ethernet cloud connected in 153 s (link: 1 s), (re)connected in 155 s
0000013304 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 13 s
0000032461 [app] INFO: Ethernet cloud connected in 14 s (link: 2 s), (re)connected in 32 s
0000020014 [app] INFO: Ethernet cloud connected in 18 s (link: 1 s), (re)connected in 20 s
0000034471 [app] INFO: Ethernet cloud connected in 32 s (link: 1 s), (re)connected in 34 s
0000013671 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000013258 [app] INFO: Ethernet cloud connected in 11 s (link: 2 s), (re)connected in 13 s
0000030818 [app] INFO: Ethernet cloud connected in 23 s (link: 1 s), (re)connected in 30 s
0000032024 [app] INFO: Ethernet cloud connected in 30 s (link: 2 s), (re)connected in 32 s
0000495976 [app] INFO: Ethernet cloud connected in 123 s (link: 2 s), (re)connected in 495 s
0000337191 [app] INFO: Ethernet cloud connected in 152 s (link: 4 s), (re)connected in 337 s
0000026480 [app] INFO: Ethernet cloud connected in 19 s (link: 0 s), (re)connected in 26 s
0000034363 [app] INFO: Ethernet cloud connected in 21 s (link: 2 s), (re)connected in 34 s
0001060390 [app] INFO: Ethernet cloud connected in 129 s (link: 0 s), (re)connected in 1060 s
0000022956 [app] INFO: Ethernet cloud connected in 21 s (link: 1 s), (re)connected in 22 s
0000023182 [app] INFO: Ethernet cloud connected in 21 s (link: 1 s), (re)connected in 23 s
0000043338 [app] INFO: Ethernet cloud connected in 41 s (link: 2 s), (re)connected in 43 s
0000028415 [app] INFO: Ethernet cloud connected in 26 s (link: 2 s), (re)connected in 28 s
0000009643 [app] INFO: Ethernet cloud connected in 7 s (link: 0 s), (re)connected in 9 s
0000018846 [app] INFO: Ethernet cloud connected in 16 s (link: 1 s), (re)connected in 18 s
0000028478 [app] INFO: Ethernet cloud connected in 26 s (link: 3 s), (re)connected in 28 s
0000199353 [app] INFO: Ethernet cloud connected in 16 s (link: 0 s), (re)connected in 199 s
0000106801 [app] INFO: Ethernet cloud connected in 104 s (link: 2 s), (re)connected in 106 s
0000052921 [app] INFO: Ethernet cloud connected in 51 s (link: 2 s), (re)connected in 52 s
0000008347 [app] INFO: Ethernet cloud connected in 6 s (link: 2 s), (re)connected in 8 s
0000040763 [app] INFO: Ethernet cloud connected in 38 s (link: 1 s), (re)connected in 40 s
0000022161 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000013423 [app] INFO: Ethernet cloud connected in 11 s (link: 1 s), (re)connected in 13 s
0000041636 [app] INFO: Ethernet cloud connected in 39 s (link: 1 s), (re)connected in 41 s
0000012230 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000196120 [app] INFO: Ethernet cloud connected in 12 s (link: 3 s), (re)connected in 196 s
0000264281 [app] INFO: Ethernet cloud connected in 75 s (link: 1 s), (re)connected in 264 s
0000012694 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 12 s
0000017769 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 17 s
0000011134 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000029673 [app] INFO: Ethernet cloud connected in 27 s (link: 1 s), (re)connected in 29 s
0000044583 [app] INFO: Ethernet cloud connected in 42 s (link: 1 s), (re)connected in 44 s
0000008879 [app] INFO: Ethernet cloud connected in 7 s (link: 1 s), (re)connected in 8 s
0000043431 [app] INFO: Ethernet cloud connected in 41 s (link: 1 s), (re)connected in 43 s
0000014418 [app] INFO: Ethernet cloud connected in 12 s (link: 1 s), (re)connected in 14 s
0000109081 [app] INFO: Ethernet cloud connected in 102 s (link: 1 s), (re)connected in 109 s
0000030290 [app] INFO: Ethernet cloud connected in 28 s (link: 1 s), (re)connected in 30 s
0000016091 [app] INFO: Ethernet cloud connected in 14 s (link: 2 s), (re)connected in 16 s
0000021295 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 21 s
0000019269 [app] INFO: Ethernet cloud connected in 12 s (link: 3 s), (re)connected in 19 s
0000021071 [app] INFO: Ethernet cloud connected in 13 s (link: 4 s), (re)connected in 21 s
0000012883 [app] INFO: Ethernet cloud connected in 11 s (link: 0 s), (re)connected in 12 s
0000019323 [app] INFO: Ethernet cloud connected in 17 s (link: 1 s), (re)connected in 19 s
0000016543 [app] INFO: Ethernet cloud connected in 14 s (link: 4 s), (re)connected in 16 s
0000011219 [app] INFO: Ethernet cloud connected in 9 s (link: 3 s), (re)connected in 11 s
0000023378 [app] INFO: Ethernet cloud connected in 10 s (link: 2 s), (re)connected in 23 s
0000018047 [app] INFO: Ethernet cloud connected in 16 s (link: 0 s), (re)connected in 18 s
0000011516 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000011008 [app] INFO: Ethernet cloud connected in 9 s (l 1 s), (re)connected in 11 s
0000011214 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000243080 [app] INFO: Ethernet cloud connected in 58 s (link: 4 s), (re)connected in 243 s
0000022113 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000030782 [app] INFO: Ethernet cloud connected in 28 s (link: 1 s), (re)connected in 30 s
0000020930 [app] INFO: Ethernet cloud connected in 19 s (link: 1 s), (re)connected in 20 s
0000015904 [app] INFO: Ethernet cloud connected in 14 s (link: 1 s), (re)connected in 15 s
0000012192 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000022649 [app] INFO: Ethernet cloud connected in 20 s (link: 1 s), (re)connected in 22 s
0000041153 [app] INFO: Ethernet cloud connected in 39 s (link: 1 s), (re)connected in 41 s
0000250965 [app] INFO: Ethernet cloud connected in 66 s (link: 4 s), (re)connected in 250 s
0000039787 [app] INFO: Ethernet cloud connected in 37 s (link: 2 s), (re)connected in 39 s
0000415568 [app] INFO: Ethernet cloud connected in 34 s (link: 2 s), (re)connected in 415 s
0000022296 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 22 s
0000684366 [app] INFO: Ethernet cloud connected in 117 s (link: 2 s), (re)connected in 684 s
0000016006 [app] INFO: Ethernet cloud connected in 8 s (link: 2 s), (re)connected in 16 s
0000011933 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 11 s
0000041667 [app] INFO: Ethernet cloud connected in 39 s (link: 1 s), (re)connected in 41 s
0000012035 [app] INFO: Ethernet cloud connected in 10 s (link: 1 s), (re)connected in 12 s
0000011067 [app] INFO: Ethernet cloud connected in 9 s (link: 1 s), (re)connected in 11 s
0000133550 [app] INFO: Ethernet cloud connected in 131 s (link: 1 s), (re)connected in 133 s
0000019659 [app] INFO: Ethernet cloud connected in 17 s (link: 1 s), (re)connected in 19 s
0000156590 [app] INFO: Ethernet cloud connected in 154 s (link: 1 s), (re)connected in 156 s
0000017231 [app] INFO: Ethernet cloud connected in 15 s (link: 4 s), (re)connected in 17 s
btw: i can get you the full log if needed. also have the "vitals" history which seem to have a lot of info
