Hi Folks,
We have a solution where we have an external circuit that is sensitive to not being queried every 10 seconds. We run Semi-Auto mode, but at some point we have to call Particle.Connect(). When we do, we could block for a good bit longer than 10 seconds. With the Electron we can figure on potentially needed to call PArticle.Connect() a good many times over the course of a day, therefore not being able to service the 10 second kick requirement.
Is there some other way of getting around Particle.connect() blocking this essential 10 second check-in?
