HI,
I am searching for a solution for a solenoid valve controller,
(ref: Need recommend for agriculture irrigation control board
Thank you. A lot of value information.
For the picture, it is solar plus a small battery.
This is whole picture.
[PXL_20220328_211142877]
For battery/power, this is no what I am concerned.
The point you said need a DC latch solenoid, it is new for me.
We have different farms.
Some close AC power and most setup with a timer controller. So we have all power ready. Just want to upgrade to iot remote control.
And, yes, pressure sensor will give us a good feedback to make sure it is running. …
I found something interesting like this.
Amazon.com: SwitchBot Smart Curtain Rod2.0 Version & Switch Button Pusher 2 Pack, Wireless App Automate Timer Control, Add SwitchBot Hub Mini to Make them Compatible with Alexa, Google Home, IFTTT : Industrial & Scientific
Since I has some projects already have a timer controller. If I have a IoT button pusher, I can just add the button to the timer and don't need to change anything.
Should be something already in the market.
Any suggestions?
