When using the Android SDK I’m getting an error when running a function that exceeds 63 characters:
Caused by: java.lang.IllegalArgumentException: Arguments ' ......' exceed max args length of 63
at io.particle.android.sdk.utils.Preconditions.checkArgument(Preconditions.java:12)
at io.particle.android.sdk.cloud.ParticleDevice.callFunction(ParticleDevice.java:388)
Same values work fine in the console. I also found this post Particle Function max characters
Am I doing something wrong or does the 63 limit still apply? Also, this works perfectly fine with the iOS SDK.
