Hi Guys,
Why does the photon give a value on analogRead when the circuit is open and 0/1 when closed?
Hi Guys,
@chrisazzopardi, a floating analog pin will be susceptible to static charge or any other electrical fields creating a voltage on the pin. Assuming you mean âgroundedâ when you say âcircuit is closedâ, a 1 bit or more error is not uncommon with ADCs, especially with 12-bit units like those in the Photon. Are you having a specific problem you need help with?
Hi @peekay123,
Thank you for your answer, its not an actual problem but trying to find the best solution. All I need to do is to connect a reed switch and detect if it is open or closed. What I am currently doing is connecting the reed switch to the A0 on one side and ground on the other.
This is returning a value when the reed switch is âopenâ and 0/1 when âclosedâ.
I was expecting to see a value of 0 when ânormally openâ and 3.3v when âclosedâ.
Why are there so much fluctuations in the value? I need to be as accurate as possible with this as it will be part of an alarm system.
Would you suggest to have the circuit in any other way? use a digital Read instead maybe?
Regards,
Chris Azzopardi
Yes use digitalRead()
setup the pin:
pinMode(A0,INPUT_PULLUP);
Put a 10k+ resistor between the reed switch and ground.
Quite apart from some inaccuracies in an onboard ADC, contact resistance in the reed switch and the breadboard you are probably prototyping, the circuit as you describe it wouldnât work anyway, where is the 3.3V you expected to be seeing when closed supposed to be coming from?
yes, since when you ground the pin through your switch, it brings the pin from its floating state down to ground or about 0volts. You could wire the A0 pin through a weak pullup resistor to the 3V3 pin; essentially fixing its state to 3.3V. analogRead()
in that state would return approx 4095, the highest 12bit value. Then when you short it to ground by closing your switch, analogRead()
should return a value towards zero.
But since you are using a binary device, try using digitalRead()
const int sensorPin = D6;
const int ledPin = D7;
pinMode(sensorPin, INPUT_PULLUP); // set pin as an input and pullup to 3.3V using internal pullup resistor
pinMode(ledPin, OUTPUT); // set on-board led to output
digitalWrite(ledPin, digitalRead(sensorPin));
the reed switch would be wired across D6 and GND in this example
@Viscacha, activating the internal pull-up and adding an external pull-down will create a voltage divider. Using digitalRead() is the best approach. I a wires leading to the reed switch are long then I suggest NOT using INPUT_PULLUP and putting a strong external pull-up to overcome wire capacitance.
@peekay123 Head in the clouds, youâre not wrong.
Isolating the Photon from the all the things that can happen to potentially long cable runs is also a good idea.
Hi All,
Am I right to say that I can use up to 18 pins for digital read?
(D0,D1,D2,D3,D4,D5,D6,D7,A0,A1,A2,A3,A4,A5,DAC,WKP,RX,TX)
Regards,
Chris Azzopardi
@chrisazzopardi, thatâs correct!
Add an I2C or SPI expander and you could read even more!
