I have a temperature and humidity sensor that generates two 4-20mA signals. Through a resistor I convert/read the signal into Volts.
I measure the signal in Volts with a photon with the following conversion:
sensorU = analogRead (A0);
voltU = (sensorU / 4095) * 3.3;
Photon is powered by USB (pc), if I change pc from a workstation to a laptop the values change.
Does anyone have a suggestion or can explain why?
Thanks Valentino
Have you checked the 3.3V reference between the two scenarios?
BTW, you should divide by 4095.0 to force a float division (unless your sensorU already is a float).
And to reduce rounding errors I’d even do it this way
voltU = (3.3 * sensorU) / 4095.0;
Hi ScruffR
Thanks for the reply. Now I notice that the cables I use for the breadboard connections and the sensors give some measurement problems. Unfortunately in the next days I am not at home I see anyway in a week to give an answer on the suggested measure. A last question: if on the pin of the photon 3V3 I measure a higher voltage for example 3.4 should I insert this or do I leave 3.3?
Thanks and have a nice day Valentino
The voltage of the 3v3 pin gives you the reference used for any ADC reading.
In order to get a correct reading your calculation should be based on the actual voltage and not the guestimated 3.3V
Not sure why you re-posted exactly the same text I wrote in my previous post
Is there another question about that?
No thank I do mistake thanks and sorry
Valentino
Hello regarding this post I made a print with the connections through soldered wires now the differences on the measures are stable
Thank you for your answers Valentino
