Hey Folks,
im new to the Photon & Particle.
I simply want to set DigitalWrite over the Tinker App of my PIN0 to High & Low, to start the neopixel Rainbow sample & shut it off again…
Im trying to understand step by step, would be happy about any hint.
So far, it´s only starting the Rainbow code…
HAPPY christmas & thanks in advance
BEN
#include "neopixel/neopixel.h"
#include "lib1.h"
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
SYSTEM_MODE(AUTOMATIC);
#define PIXEL_PIN D0
#define PIXEL_COUNT 28
#define PIXEL_TYPE WS2812B
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
strip.begin();
strip.show();
Particle.function("digitalread", tinkerDigitalRead);
Particle.function("digitalwrite", tinkerDigitalWrite);
void rainbow(uint8_t wait);
uint32_t Wheel(byte WheelPos);
rainbow(20);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
int pinNumber = pin.charAt(1) - '0';
if (pinNumber< 0 || pinNumber >7) return -1;
if(pin.startsWith("D"))
pinMode(pinNumber, INPUT_PULLDOWN);
return digitalRead(pinNumber);
else if (pin.startsWith("A"))
pinMode(pinNumber+10, INPUT_PULLDOWN);
return digitalRead(pinNumber+10);
return -2;
bool value = 0;
int pinNumber = command.charAt(1) - '0';
if(command.substring(3,7) == "HIGH") value = 1;
else if(command.substring(3,6) == "LOW") value = 0;
else return -2;
if(command.startsWith("D"))
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, value);
return 1;
else if(command.startsWith("A"))
pinMode(pinNumber+10, OUTPUT);
digitalWrite(pinNumber+10, value);
return 1;
else return -3;
