After runnung sudo npm install -g particle-cli and succesfuly instaling it I used CoolTerm to connect my year old Spark Core to wifi. Good its flashing cyan, but running comand it finds no such particle comand
particle cloud login
-bash: particle: command not found
I have no idea why this ir not working - i just cannot claim my spark core
after installing particle terminal logs:
/usr/local/Cellar/node/5.4.0/libexec/npm/bin/particle -> /usr/local/Cellar/node/5.4.0/libexec/npm/lib/node_modules/particle-cli/bin/particle.js
> serialport@2.0.6 install /usr/local/Cellar/node/5.4.0/libexec/npm/lib/node_modules/particle-cli/node_modules/serialport
> node-pre-gyp install --fallback-to-build
[serialport] Success: "/usr/local/Cellar/node/5.4.0/libexec/npm/lib/node_modules/particle-cli/node_modules/serialport/build/Release/node-v46-darwin-x64/serialport.node" is installed via remote
└─┬ particle-cli@1.8.22
├─┬ chalk@1.1.1
│ ├── ansi-styles@2.1.0
│ ├── escape-string-regexp@1.0.4
│ ├─┬ has-ansi@2.0.0
│ │ └── ansi-regex@2.0.0
│ ├── strip-ansi@3.0.0
│ └── supports-color@2.0.0
├── cli-spinner@0.2.1
├─┬ cli-table@0.3.1
│ └── colors@1.0.3
├── fast-luhn@1.0.2
├─┬ glob@4.5.3
│ ├─┬ inflight@1.0.4
│ │ └── wrappy@1.0.1
│ ├── inherits@2.0.1
│ ├─┬ minimatch@2.0.10
│ │ └─┬ brace-expansion@1.1.2
│ │ ├── balanced-match@0.3.0
│ │ └── concat-map@0.0.1
│ └── once@1.3.3
├── hogan.js@2.0.0
├─┬ inquirer@0.8.5
│ ├── ansi-regex@1.1.1
│ ├── cli-width@1.1.0
│ ├── figures@1.4.0
│ ├─┬ readline2@0.1.1
│ │ ├── mute-stream@0.0.4
│ │ └─┬ strip-ansi@2.0.1
│ │ └── ansi-regex@1.1.1
│ ├── rx@2.5.3
│ └── through@2.3.8
├── lodash@3.10.1
├── moment@2.11.0
├─┬ node-wifiscanner2@1.1.0
│ └─┬ os-locale@1.4.0
│ └─┬ lcid@1.0.0
│ └── invert-kv@1.0.0
├─┬ request@2.67.0
│ ├── aws-sign2@0.6.0
│ ├─┬ bl@1.0.0
│ │ └─┬ readable-stream@2.0.5
│ │ ├── core-util-is@1.0.2
│ │ ├── isarray@0.0.1
│ │ ├── process-nextick-args@1.0.6
│ │ ├── string_decoder@0.10.31
│ │ └── util-deprecate@1.0.2
│ ├── caseless@0.11.0
│ ├─┬ combined-stream@1.0.5
│ │ └── delayed-stream@1.0.0
│ ├── extend@3.0.0
│ ├── forever-agent@0.6.1
│ ├─┬ form-data@1.0.0-rc3
│ │ └── async@1.5.2
│ ├─┬ har-validator@2.0.3
│ │ ├─┬ commander@2.9.0
│ │ │ └── graceful-readlink@1.0.1
│ │ ├─┬ is-my-json-valid@2.12.3
│ │ │ ├── generate-function@2.0.0
│ │ │ ├─┬ generate-object-property@1.2.0
│ │ │ │ └── is-property@1.0.2
│ │ │ └── jsonpointer@2.0.0
│ │ └─┬ pinkie-promise@2.0.0
│ │ └── pinkie@2.0.1
│ ├─┬ hawk@3.1.2
│ │ ├── boom@2.10.1
│ │ ├── cryptiles@2.0.5
│ │ ├── hoek@2.16.3
│ │ └── sntp@1.0.9
│ ├─┬ http-signature@1.1.0
│ │ ├── assert-plus@0.1.5
│ │ ├─┬ jsprim@1.2.2
│ │ │ ├── extsprintf@1.0.2
│ │ │ ├── json-schema@0.2.2
│ │ │ └── verror@1.3.6
│ │ └─┬ sshpk@1.7.2
│ │ ├── assert-plus@0.2.0
│ │ ├── dashdash@1.12.0
│ │ ├── ecc-jsbn@0.1.1
│ │ ├── jodid25519@1.0.2
│ │ ├── jsbn@0.1.0
│ │ └── tweetnacl@0.13.3
│ ├── is-typedarray@1.0.0
│ ├── isstream@0.1.2
│ ├── json-stringify-safe@5.0.1
│ ├─┬ mime-types@2.1.9
│ │ └── mime-db@1.21.0
│ ├── node-uuid@1.4.7
│ ├── oauth-sign@0.8.0
│ ├── qs@5.2.0
│ ├── stringstream@0.0.5
│ ├── tough-cookie@2.2.1
│ └── tunnel-agent@0.4.2
├─┬ serialport@2.0.6
│ ├── async@0.9.0
│ ├── bindings@1.2.1
│ ├─┬ debug@2.2.0
│ │ └── ms@0.7.1
│ ├── nan@2.0.9
│ ├─┬ node-pre-gyp@0.6.18
│ │ ├─┬ npmlog@2.0.0
│ │ │ └─┬ are-we-there-yet@1.0.5
│ │ │ └─┬ readable-stream@2.0.5
│ │ │ ├── core-util-is@1.0.2
│ │ │ ├── inherits@2.0.1
│ │ │ ├── isarray@0.0.1
│ │ │ ├── process-nextick-args@1.0.6
│ │ │ ├── string_decoder@0.10.31
│ │ │ └── util-deprecate@1.0.2
│ │ ├─┬ rc@1.1.5
│ │ │ └── ini@1.3.4
│ │ ├─┬ request@2.67.0
│ │ │ ├── aws-sign2@0.6.0
│ │ │ ├─┬ bl@1.0.0
│ │ │ │ └─┬ readable-stream@2.0.5
│ │ │ │ ├── core-util-is@1.0.2
│ │ │ │ ├── inherits@2.0.1
│ │ │ │ ├── isarray@0.0.1
│ │ │ │ ├── process-nextick-args@1.0.6
│ │ │ │ ├── string_decoder@0.10.31
│ │ │ │ └── util-deprecate@1.0.2
│ │ │ ├── caseless@0.11.0
│ │ │ ├─┬ combined-stream@1.0.5
│ │ │ │ └── delayed-stream@1.0.0
│ │ │ ├── extend@3.0.0
│ │ │ ├── forever-agent@0.6.1
│ │ │ ├── form-data@1.0.0-rc3
│ │ │ ├─┬ har-validator@2.0.3
│ │ │ │ ├─┬ chalk@1.1.1
│ │ │ │ │ ├── ansi-styles@2.1.0
│ │ │ │ │ ├─┬ has-ansi@2.0.0
│ │ │ │ │ │ └── ansi-regex@2.0.0
│ │ │ │ │ ├─┬ strip-ansi@3.0.0
│ │ │ │ │ └── supports-color@2.0.0
│ │ │ │ ├─┬ commander@2.9.0
│ │ │ │ │ └── graceful-readlink@1.0.1
│ │ │ │ ├─┬ is-my-json-valid@2.12.3
│ │ │ │ │ ├── generate-function@2.0.0
│ │ │ │ │ ├─┬ generate-object-property@1.2.0
│ │ │ │ │ │ └── is-property@1.0.2
│ │ │ │ │ ├── jsonpointer@2.0.0
│ │ │ │ │ └── xtend@4.0.1
│ │ │ │ └─┬ pinkie-promise@2.0.0
│ │ │ │ └── pinkie@2.0.1
│ │ │ ├─┬ hawk@3.1.2
│ │ │ │ ├── boom@2.10.1
│ │ │ │ ├── cryptiles@2.0.5
│ │ │ │ ├── hoek@2.16.3
│ │ │ │ └── sntp@1.0.9
│ │ │ ├─┬ http-signature@1.1.0
│ │ │ │ ├── assert-plus@0.1.5
│ │ │ │ ├─┬ jsprim@1.2.2
│ │ │ │ │ ├── extsprintf@1.0.2
│ │ │ │ │ ├── json-schema@0.2.2
│ │ │ │ │ └── verror@1.3.6
│ │ │ │ └─┬ sshpk@1.7.1
│ │ │ │ ├── asn1@0.2.3
│ │ │ │ ├── assert-plus@0.2.0
│ │ │ │ ├─┬ dashdash@1.10.1
│ │ │ │ │ └── assert-plus@0.1.5
│ │ │ │ ├── ecc-jsbn@0.1.1
│ │ │ │ ├── jodid25519@1.0.2
│ │ │ │ └── jsbn@0.1.0
│ │ │ ├── is-typedarray@1.0.0
│ │ │ ├── isstream@0.1.2
│ │ │ ├── json-stringify-safe@5.0.1
│ │ │ ├── node-uuid@1.4.7
│ │ │ ├── oauth-sign@0.8.0
│ │ │ ├── qs@5.2.0
│ │ │ ├── stringstream@0.0.5
│ │ │ ├── tough-cookie@2.2.1
│ │ │ └── tunnel-agent@0.4.2
│ │ ├─┬ rimraf@2.4.4
│ │ │ └─┬ glob@5.0.15
│ │ │ ├─┬ inflight@1.0.4
│ │ │ │ └── wrappy@1.0.1
│ │ │ ├─┬ minimatch@3.0.0
│ │ │ │ └─┬ brace-expansion@1.1.2
│ │ │ │ ├── balanced-match@0.3.0
│ │ │ │ └── concat-map@0.0.1
│ │ │ └─┬ once@1.3.3
│ │ ├─┬ tar@2.2.1
│ │ │ └── inherits@2.0.1
│ │ └─┬ tar-pack@3.1.2
│ │ ├─┬ fstream@1.0.8
│ │ ├─┬ fstream-ignore@1.0.3
│ │ │ └─┬ minimatch@3.0.0
│ ├─┬ node-pre-gyp-github@1.1.1
│ │ └─┬ request@2.67.0
│ │ ├─┬ bl@1.0.0
│ │ │ │ ├── escape-string-regexp@1.0.4
│ │ ├─┬ hawk@3.1.2
│ │ ├── qs@5.2.0
│ ├─┬ optimist@0.6.1
│ │ ├── minimist@0.0.10
│ │ └── wordwrap@0.0.3
│ └── sf@0.1.7
├─┬ softap-setup@1.1.4
│ ├─┬ nconf@0.7.2
│ │ ├── async@0.9.2
│ │ ├── ini@1.3.4
│ │ └─┬ yargs@3.15.0
│ │ ├── camelcase@1.2.1
│ │ ├─┬ cliui@2.1.0
│ │ │ ├─┬ center-align@0.1.2
│ │ │ │ ├─┬ align-text@0.1.3
│ │ │ │ │ ├─┬ kind-of@2.0.1
│ │ │ │ │ │ └── is-buffer@1.1.1
│ │ │ │ │ ├── longest@1.0.1
│ │ │ │ │ └── repeat-string@1.5.2
│ │ │ │ └── lazy-cache@0.2.7
│ │ │ ├── right-align@0.1.3
│ │ │ └── wordwrap@0.0.2
│ │ ├── decamelize@1.1.2
│ │ └── window-size@0.1.4
│ └─┬ node-rsa@0.2.26
│ ├── asn1@0.2.3
│ └── lodash@3.3.0
├── when@3.7.7
└── xtend@4.0.1
