I’m trying to wake up an electron board from sleep using an ADXL345 accelerometer. I can correctly write to the accelerometer using I2C, as well as read from it, but I can’t make the interrupt pin fire to wake up the WXP pin on the Electron Particle.
Here’s the datasheet I’m looking at:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADXL345.pdf
and here’s the library I’m using:
https://github.com/particle-iot/spark-lib-adxl345
#include <adxl345.h>
SYSTEM_MODE(SEMI_AUTOMATIC);
#define ACCELADDRESS 0x53
ADXL345 accel;
unsigned long firstAvailable = 0;
int couunter;
// put your setup code here, to run once:
delay(4000);
Serial.println("setup called");
Serial.println("wakeonmove 6/5/2019");
Wire.begin();
accel.powerOn();
write_register(ACCELADDRESS, 0x24, 0x10);
write_register(ACCELADDRESS, 0x25, 0x10);
write_register(ACCELADDRESS, 0x26, 0x0A);
write_register(ACCELADDRESS, 0x27, 0x77);
write_register(ACCELADDRESS, 0x2D, 0x30); //accelerometer auto-sleep
write_register(ACCELADDRESS, 0x2F, 0x10);
write_register(ACCELADDRESS, 0x2E, 0x10);
Serial.println(read_register(ACCELADDRESS, 0x24));
Serial.println(read_register(ACCELADDRESS, 0x25));
Serial.println(read_register(ACCELADDRESS, 0x26));
Serial.println(read_register(ACCELADDRESS, 0x27));
Serial.println(read_register(ACCELADDRESS, 0x2D)); //accelerometer auto-sleep
Serial.println(read_register(ACCELADDRESS, 0x2F));
Serial.println(read_register(ACCELADDRESS, 0x2E));
Serial.println("SETUP COMPLETE"); Serial.println();
//bool wifiReady = WiFi.ready();
bool cloudReady = Particle.connected();
//Serial.printlnf("wifi=%s cloud=%s counter=%d", (wifiReady ? "on" : "off"), (cloudReady ? "on" : "off"), counter++);
if (true) {
if (firstAvailable == 0) {
firstAvailable = millis();
if (millis() - firstAvailable > 30000) {
// After we've been up for 30 seconds, go to sleep
Serial.println("calling System.sleep(WKP, RISING, 30)");
// This delay is here so the serial print above goes out before going to sleep
delay(1);
System.sleep(WKP, RISING, 30);
read_register(ACCELADDRESS, 0x30);
// In this mode, setup() is not called again. Sometimes, but not always, the Serial port does
// not restore properly. This solves the problem.
delay(1000);
// In this mode,after the sleep period is done, execution continues where we left off,
// with variables intact.
Serial.println("returned from sleep");
// Important! If you don't reset this, you'll immediately go back to sleep, since variables
// are preserved.
firstAvailable = 0;
else {
firstAvailable = 0;
delay(1000);
byte read_register(int I2CAddress, byte address)
//Send a request
//Start talking to the device at the specified address
Wire.beginTransmission(I2CAddress);
//Send a bit asking for requested register address
Wire.write(address);
//Complete Transmission
Wire.endTransmission(false);
//Read the register from the device
//Request 1 Byte from the specified address
Wire.requestFrom(I2CAddress, 1);
//wait for response
while(Wire.available() == 0);
// Get the temp and read it into a variable
byte data = Wire.read();
return data;
// Writes a single byte (data) into address
void write_register(int I2CAddress, unsigned char address, unsigned char data)
//Send a request
Wire.write(data);
Reading from the registers shows me the same things I write to them, and, in a different code, when I read from the interrupt source(0x30) and print it to screen, it shows that the Activity interrupt is working on the ADXL345. The problem is that the WXP pin never fires and never wakes up the board.
I don’t know what’s going on, so any help would be appreciated. Thanks!
