Adding time to millis()?
Is there a good way to artificially add time to the millis() value? What I’ve tried so far hasn’t worked.
I have a project that uses millis() for timing, but also disables interrupts often enough that millis() loses significant time. I’m trying to find a way to mitigate that by adding time back to millis() based upon micros(), but I havent had much luck. I’m not looking for 100% millis accuracy, but closer than “not close at all” would be cool. :slight_smile:
It looks like I can call System1MsTick directly, but I’m not having much luck there. Here is my test code:
void setup(){
    delay(10000); // Give myself time to get serial connection started
    uint32_t startMillis = millis();
    delay(10);
    Serial.println(String(millis()) + " " + String(millis()-startMillis));
    for(int i = 0; i < 1000; ++i) {
        System1MsTick();
Hammering System1MsTick seems to have no effect at all. Is there a better way to do this?
a good read on millis() and micros() and stopping interrupts.
I’ve done this with Arduino to calibrate the clock depending on temperature:
Off the top of my head:
x=somevalue;
d=1000; //1 sec
n++;
if (n%x==0) d++; //or d–
delay(d);
I believe the fix for millis() running slow is a relatively easy one - I’ll try to get that in for 0.5.0
Ha, yeah, it’d definitely be nicer if millis didnt run slow in the first place. But I’m also fine with fudging it if it’d let me. :slight_smile:
