Adding Paths to Workbench(VSCode) intellisense
I've added a custom build.mk which now includes some directories for tidying my code up. The build.mk works fine but I can't seem to get VSCode to intellisense correctly. With the following build.mk what do I need to add to VSCode to get intellisense working.
INCLUDE_DIRS += $(SOURCE_PATH)inc
INCLUDE_DIRS += $(wildcard $(SOURCE_PATH)/lib/common/*/src)
INCLUDE_DIRS += $(wildcard $(SOURCE_PATH)lib/modules/*/src)
## Standard behavior must be included here
INCLUDE_DIRS += $(SOURCE_PATH)$(USRSRC)  # add user sources to include path
CPPSRC += $(call target_files,$(USRSRC_SLASH),*.cpp)
CSRC += $(call target_files,$(USRSRC_SLASH),*.c)
APPSOURCES=$(call target_files,$(USRSRC_SLASH),*.cpp)
APPSOURCES+=$(call target_files,$(USRSRC_SLASH),*.c)
I've tried adding the following to settings.json but it doesn't seem to be picked up, I suspect that the particle-vscode-core provider is overriding my settings.
    "extensions.ignoreRecommendations": true,
    "C_Cpp.default.configurationProvider": "particle.particle-vscode-core",
    "files.associations": {
        "*.ino": "cpp"
    "configurations": [
            "name": "inc",
            "includePath": [
                "${workspaceFolder}/inc/**",
                "${workspaceFolder}/lib/common/**",
                "${workspaceFolder}/inc/modules/**",
                "${default}"
    "C_Cpp.default.browse.path": ["${workspaceFolder}/inc"],
    "C_Cpp.default.includePath": ["${workspaceFolder}/inc"],
    "C_Cpp.default.systemIncludePath": ["${workspaceFolder}/inc"],
    "particle.firmwareVersion": "6.2.1",
    "particle.targetPlatform": "b5som",
    "particle.enableVerboseLocalCompilerLogging": true
What is the specific include file path that's not being picked up by Intellisense that should be?
The first three lines as detailed in the first message in the build.mk in this post.
Currently the only way I can get intellisense looking in the directories specified in the build.mk is to add it as a c_cpp_properties.json file and disable the particle configurationProvider and use the default provider. Needless to say this is a bit cumbersome as I now have to rebuild what the particle provider puts into the include list including all the Defines, which could and I suspect would change on every release.
