Is there a way to add a linefeed to the data displayed in the event data window? I have tried adding \r and \n to the data but the event viewer ignore them. I would like the data a little more readable.
Albert
Albert
Let me ping someone that might be able to help, @ParticleD, or @mstanley are you able to assist?
I am not aware of a way to do that, but alternatively you could write a script or program that accesses the same data and then formats it in any way you want. E.g.
curl "https://api.particle.io/v1/products/9999/events?access_token=<your access token>"
will dump out all events from all devices in Product 9999. You can do that for individual devices as well; I just happened to have that example handy. You can also filter for events that start with a certain string.
More info is here.
@albertk836 Hey! I just wanted to check to see if @ParticleD’s response was helpful in solving your problem or not. Let us know!
Kevin
I just started looking into ParticleD suggestion. will update.
Thank You!
Albert
