@mihaigalos, Libraries 2.0 will be releasing very shortly. I will be going through my repo after that to see what needs to be moved over and not. I hope you don’t mind waiting till then!
Dear @peekay123,
I tested my OLED spi on arduino Uno, it worked fine. But I want to use on ESP8266 v7, it doesn’t work. I don’t know reason why? What’s different between esp8266 v7 and NODE MCU?
This is my OLED display
This isn’t really a ESP8266 forum.
You may get better advice in the dedicated forums
Thank you! Your code worked with the OLED I just purchased from Amazon.
