Adafruit_RA8875?
Does anyone know if there is a working Spark conversion for this library? I’m planning a project, and would really dig one of those nice big touchscreens. :smile:
The board in question:
RA8875 TFT Driver Board
The library in question:
RA8875 Arduino Library
Any help would be greatly appreciated!
I’m not aware of a finished port of this lib, but just skimming over the code it looks quite portable.
@screamingcities, please keep your questions to a single post. I already answered this on the mfGFX library topic:
Oh sorry peeKay, I’d actually already posted this before you responded, and I posted this figuring it was a question that should probably be it’s own thing rather then just randomly in another post- didn’t mean to offend?
Thanks for the info though… Any kind of good tutorials on porting libraries? I’ve never done so, and I’m honestly not sure where to begin.
@screamingcities, in this case porting sounds bigger than it actually is, since there’s no bare metal programming required.
Some basic tips & hints you’ll find here
As long you can read C/C++ you’ll find your way round.
One thing to consider in this case is the different CPU speed, so you’ll have to adjust the SPI_CLOCK_DIV
e.g.
#if defined(SPARK)
    SPI.setClockDivider(SPI_CLOCK_DIV32);
#else
  #ifdef __AVR__
    SPI.setClockDivider(SPI_CLOCK_DIV4);
  #endif
#endif
I know this is an old thread, but I started a project that uses the Driver Board linked above and a 7-inch 800x480 resistive display.
The Adafruit_RA8875 library is working very well for me on a photon. I did have to make one slight modification to the library though. In Adafruit_RA8875.cpp I had to add the following line:
#define SPI_HAS_TRANSACTION 1
