Hey I got mine working on 4 chips. I had previously bought this: http://www.ebay.com/itm/MAX31855K-Quad-Ch-Type-K-Thermocouple-Breakout-270C-1372C-MAX6675-upgrade-/330866913450?pt=LH_DefaultDomain_0&hash=item4d093470aa and so far this works.
It also includes code to format the data for parsing with json and read the thermocouples out to a google spreadsheet.
It's still prob got a lot of stuff wrong with it.
double thermoTemp = 0;
double internalTemp = 0;
bool hasError = false;
bool scvFault = false;
bool scgFault = false;
bool ocFault = false;
unsigned long raw = 0;
typedef struct {
int ThermoTemp : 14;
unsigned char Reserved : 1;
bool Fault : 1;
int InternalTemp : 12;
unsigned char Reserved2 : 1;
bool SCVFault : 1;
bool SCGFault : 1;
bool OCFault : 1;
} Temp;
union Reading {
unsigned long bit32;
unsigned int bit16[2];
unsigned char bit8[4];
Temp temp;
char resultstr[64];
pinMode(D0,OUTPUT); //Set these pins to output for CS0-3
pinMode(D1,OUTPUT);
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D7,OUTPUT); // Turn on the D7 led so we know it's time
digitalWrite(D7,HIGH); // to open the Serial Terminal.
Serial.begin(9600); // Open serial over USB.
// while(!Serial.available()); // Wait here until the user presses ENTER in the Serial Terminal
digitalWrite(D7,LOW); // Turn off the D7 led ... your serial is serializing!
Serial.println("MAX31855 test");
// wait for MAX chip to stabilize
delay(1000);
Spark.variable("hasError", &hasError, BOOLEAN);
Spark.variable("scvFault", &scvFault, BOOLEAN);
Spark.variable("scgFault", &scgFault, BOOLEAN);
Spark.variable("ocFault", &ocFault, BOOLEAN);
Spark.variable("thermoTemp", &thermoTemp, DOUBLE);
Spark.variable("internalTemp", &internalTemp, DOUBLE);
Spark.variable("raw", &raw, INT);
Spark.variable("result", &resultstr, STRING);
SPI.setClockDivider(SPI_CLOCK_DIV64);
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE3);
SPI.begin();
//Connect SO to A4
//Connect SCK to A3
//CS0-3 to D0-3
digitalWrite(D0, HIGH);
digitalWrite(D1, HIGH);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
double t0;
double t1;
double t2;
double t3;
t0 = readChip(0,1);
t1 = readChip(1,1);
t2 = readChip(2,1);
t3 = readChip(3,1);
sprintf(resultstr, "{\"t2\":%f,\"t3\":%f}", t2, t3);
delay(1000);
double readChip(int chip, bool print){
//read the temperature from the thermocouple connected to 'chip'
//print the data to the serial port if print is true
Reading reading;
//clear the data
reading.bit32 = 0;
digitalWrite(("D",chip), LOW);
delay(1);
//read in the 32-bit value
for(int i =3; i >= 0 ; i--) {
reading.bit8[i] = SPI.transfer(0);
thermoTemp = (0x80000000 & reading.bit32 ? -1.0 : 1.0) * (double)((reading.bit32 >> 18) & 0x00001FFF) / 4.0;
internalTemp =(0x00008000 & reading.bit32 ? -1.0 : 1.0) * (double)((reading.bit32 >> 4) & 0x000007FF) / 16.0;
hasError = reading.temp.Fault;
scvFault = reading.temp.SCVFault;
scgFault = reading.temp.SCGFault;
ocFault = reading.temp.OCFault;
raw = reading.bit32;
digitalWrite(("D",chip), HIGH);
double tempF;
tempF = (thermoTemp*9.0/5.0+32.0);
if (print = true) {
Serial.print("T");
Serial.print(chip);
Serial.print(" = ");
Serial.print(tempF);
Serial.print(" F");
Serial.println("");
delay(100);
return tempF;
