A program that was working perfectly a couple of weeks ago, can no longer compile on the WEB IDE. It look like the problems relate to the Adafruit BMP085 library for the temperature / barometer sensor.
it comes up with multiple errors that are similar to this
lib/Adafruit_BMP085/src/Adafruit_BMP085.h:60:17: error: 'uint8_t' has not been declared
boolean begin(uint8_t mode = BMP085_ULTRAHIGHRES); // by default go highres
lib/Adafruit_BMP085/src/Adafruit_BMP085.h:62:3: error: 'int32_t' does not name a type
int32_t readPressure(void);
I have done the following to resolve the problem:
I removed the library from the program and added it back.
I cleared the cash, logged out, and restarted the web IDE.
I have changed absolutely nothing from my previous compile, so I cannot understand why this is happening.
Is it me or does it have something to do with the library upgrade?
@Grenello, the Adafruit_BMP085 library has not been ported to V2.0 by the author and I suspect this is the root of the problem. It has not been touched since it was first published in 2014. I’ll raise an issue on the Author’s repo.
