leave
is for the DFU-util to ask the core to reset after downloading via USB
Blink some lights and celebrate the birth of your core?
leave
Hi @johnbo,
Awesome, glad you got it working!
The spark keys doctor
command is maybe still a bit too brittle, and should do more to check modes, give better prompts, and retry if there are failures. Iâm guessing something like, the writeKeyToCore
command reported a failure and it didnât progress. Iâm glad you were able to dig in! Yay open source!
If you felt like it, a bug report / issue on the github repo would be very appreciated: https://github.com/spark/spark-cli/issues?state=open
David
Iâll file a bug report this evening. Unfortunately, the day job conflicts with the fun bitsâŚ
Later,
johnbo
@Dave @zachary - Hi, think I have a handshake issue. Have just emailed ID and key to hello@spark.io.
Hope this info is helpful and can get core connected soon.
Rick
After the spark keys doctor
, I also needed to do the spark keys send core
âŚ
It is probably worthwhile getting the documentation updated for spark
to reflect that you might need to do this
Hi @vk2tds,
Thanks! The keys doctor is supposed to do this as well, there was a bug on this, but I thought it was fixed. Iâll double-check.
David
I moved 17 posts to a new topic: Core not accepting new private key
Thx @Dave, worked like a charm!
Hi
I have a problem with my core, after send it the WIFI credentials, the Led began blinking in cyan, after that changed to red/yellow and finally to red, and again the cycle.
I read the help here, and try create the new keys for my core with command $ spark keys doctor, but make an error:
c:\dfu\win32>spark keys doctor 54ff6c066667515148491267
running dfu-util -l
FOUND DFU DEVICE 1d50:607f
running openssl genrsa -out 54ff6c066667515148491267_new.pem 1024
Error creating keys⌠Error: Command failed: âopensslâ no se reconoce como un comando interno o externo,programa o archivo por lotes ejecutable.
Make sure your core is in DFU mode (blinking yellow), and that your computer is
online.
Error - Error: Command failed: âopensslâ no se reconoce como un comando interno
o externo,
I reinstall the openSSL program and try again but the result is the same.
The spark version is 0.4.4
I hope you can help me.
Thank you
Ayax
Hi @Yackodrino,
It looks like your openssl installation probably isnât on your path, which would make sense if you installed it, but it canât be found. The path variable tells windows where to look for programs, hereâs a random article on how to add stuff to it for various versions of windows:
http://docs.oracle.com/javase/tutorial/essential/environment/paths.html
I hope that helps!
David
This is awesome. If youâre not certain if this is the right fix for you - here is a video displaying the color-rotation observed that I recored of my core for which this solved the issue.
How do you find and send the new public key?
Hi @ryanwoltz,
The CLI keys doctor command will attempt to do this for you if youâre logged in:
particle keys doctor you_device_id
#or you can send the key manually with:
particle keys send you_device_id your_new_key.pub.pem
David
I know these instructions are bit dated at this point, but how do you handle an error such as this one?:
Hi @helenvholmes,
Once your device and the cloud decide on a key, it becomes "lockedâ by the owner of that device until a new key is sent. This error means that someone else / a different claimed that core that youâre using, so the cloud wonât let you change its key.
edit: the other possibility is that this device wasnât provisioned on the cloud properly. If you grab the DeviceID from the device and email us at hello@particle.io we can help get you up and running quickly!
David
Hello,
I have been having this problem with a Spark Core (rapid flashing orange light) and I have successfully worked through most of the steps to generate new keys. The last part fails though: âparticle keys send deviceID generated_public_key.pemâ gives the output âError sending public key to server: Permission Deniedâ.
Does this method no longer work? I resorted to it as the doctor command didnât work. I could e-mail the public key.
Hi @dansw81,
Good question! This feature still works, but youâll be denied access if the device has been claimed by a different user. And you need to make sure the âdeviceIDâ part is a literal deviceID 300xxxx00xxxx4323xxxx23x, etc.
Feel free to send me the public key and device id if you want, and I can help get things working again if youâre still stuck.
David
