Steps to use libraries 2.0
Libraries 2.0 needs support in the CLI and firmware, so follow these steps to get started using it.
  1. Install a pre-release version of the CLI
    npm install -g https://github.com/spark/particle-cli/releases/download/v1.19.0-libraries.23/particle-cli-1.19.0-libraries.23.tgz
  2. Update your device to 0.5.3 firmware or later (on the Photon, you can skip this step and rely on safe mode healer)
  3. Create a new folder for your project. The CLI will save the library dependencies in project.properties
    +- application.cpp +- project.properties <-- will be created by the CLI and contain library dependencies
  4. Add a library such as neopixel library as a dependency
    particle library add neopixel
  5. You should see Added library neopixel 0.0.10 to project
    And the line dependencies.neopixel=0.0.10 should appear in project.properties
  6. Compile/flash the project using the pre-release firmware
    particle flash my_photon .
Please reply to this topic with tool installation issues. If you have other comments and suggestions let’s discuss that in a separate topic.
On Monday you should also be able to use Libraries 2.0 with v0.5.3-rc.3, and then v0.5.3 (default) at the end of next week.
KENMBP:~ kennethlimcp$ p --version
2.0.0-libraries.2
KENMBP:cli-lib kennethlimcp$ mkdir src
KENMBP:cli-lib kennethlimcp$ cd src/
KENMBP:src kennethlimcp$ touch application.cpp
KENMBP:src kennethlimcp$ ..
KENMBP:cli-lib kennethlimcp$ particle add library neopixel
Usage: library <command>
Commands:
  init     Initializes a new library in the specified or current directory..
  install  installs a library
  migrate  Migrates a local library from v1 to v2 format.
  add      Add a library to the current project.
Global Options:
  --args             Path to JSON config file
  -v, --verbose      How much logging to display                         [count]
  --interactive      forces interactive mode                           [boolean]
  --non-interactive  Run in non-interactive mode. This means all required data
                     must be passed as command line arguments.         [boolean]
  --json             Output in JSON format instead of human friendly   [boolean]
  --help             Provides extra details and options for a given command
        [boolean]
No such command 'library library neopixel'
KENMBP:cli-lib kennethlimcp$ particle compile photon . --target 0.6.0-libraries.1
Compiling code for photon
Targeting version: 0.6.0-libraries.1
Including:
    /Users/kennethlimcp/Desktop/cli-lib/project.properties
    /Users/kennethlimcp/Desktop/cli-lib/src/application.cpp
downloading binary from: /v1/binaries/57c0da14f917f2b94bd09094
saving to: photon_firmware_1472256527659.bin
Compile succeeded.
Saved firmware to: /Users/kennethlimcp/Desktop/cli-lib/photon_firmware_1472256527659.bin
The above command should be particle library add neopixel
Other than that, things are looking great :smiley:
I fixed the instructions to say particle library add neopixel. Please give it a shot again Kenneth!
I gave it a shot the moment it gave me errors.
It’s working great with an example app. :beers:
I read the terminal output, but misread the comment :sweat_smile: Friday night… :beers: to you too!
After executing this command on my Win 8.1Pro64bit (no laughing!) I get this
C:\Users\Andy>node --version
v4.2.4
C:\Users\Andy>npm --version
2.14.12
C:\Users\Andy>particle --version
module.js:340
    throw err;
Error: Cannot find module 'es6-promisify'
    at Function.Module._resolveFilename (module.js:338:15)
    at Function.Module._load (module.js:289:25)
    at Module.require (module.js:366:17)
    at require (module.js:385:17)
    at Object.<anonymous> (C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\library_init.js:20:17)
    at Module._compile (module.js:435:26)
    at Object.Module._extensions..js (module.js:442:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:313:12)
Is there another node update required? Or what else could be wrong?
That was my output during one of my tries
C:\Users\Andy>npm install -g https://github.com/spark/particle-cli/releases/download/v2.0.0-libraries.2/particle-cli-2.0.0-libraries.2.tgz
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
> spawn-sync@1.0.15 postinstall C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\node_modules\yeoman-environment\node_modules\inquirer\node
_modules\external-editor\node_modules\spawn-sync
> node postinstall
> spawn-sync@1.0.15 postinstall C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\node_modules\particle-cli-library-manager\node_modules\yeo
man-generator\node_modules\yeoman-test\node_modules\inquirer\node_modules\external-editor\node_modules\spawn-sync
> node postinstall
> serialport@3.1.2 install C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport
> node-pre-gyp install --fallback-to-build
[serialport] Success: "C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\build\Release\serialport.node" is installed
 via remote
C:\Users\Andy\AppData\Roaming\npm\particle -> C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli\bin\particle.js
particle-cli@2.0.0-libraries.2 C:\Users\Andy\AppData\Roaming\npm\node_modules\particle-cli
β”œβ”€β”€ cli-spinner@0.2.5
β”œβ”€β”€ xtend@4.0.1
β”œβ”€β”€ semver@5.3.0
β”œβ”€β”€ chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1)
β”œβ”€β”€ temp@0.8.3 (os-tmpdir@1.0.1, rimraf@2.2.8)
β”œβ”€β”€ cli-table@0.3.1 (colors@1.0.3)
β”œβ”€β”€ glob@4.5.3 (inherits@2.0.1, once@1.3.3, inflight@1.0.5, minimatch@2.0.10)
β”œβ”€β”€ node-wifiscanner2@1.2.0 (os-locale@1.4.0)
β”œβ”€β”€ inquirer@0.11.4 (strip-ansi@3.0.1, ansi-regex@2.0.0, ansi-escapes@1.4.0, through@2.3.8, rx-lite@3.1.2, cli-width@1.1.1, figures@1.7.0, string-widt
h@1.0.2, readline2@1.0.1, cli-cursor@1.0.2, run-async@0.1.0)
β”œβ”€β”€ when@3.7.7
β”œβ”€β”€ form-data@1.0.0-rc4 (async@1.5.2, combined-stream@1.0.5, mime-types@2.1.11)
β”œβ”€β”€ binary-version-reader@0.4.0 (buffer-crc32@0.2.5, h5.buffers@0.1.1)
β”œβ”€β”€ latest-version@2.0.0 (package-json@2.4.0)
β”œβ”€β”€ hogan.js@2.0.0
β”œβ”€β”€ request@2.74.0 (aws-sign2@0.6.0, tunnel-agent@0.4.3, forever-agent@0.6.1, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0
.5, aws4@1.4.1, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, tough-cookie@2.3.1, qs@6.2.1, node-uuid@1.4.7, combined-stream@1.0.5, mime-ty
pes@2.1.11, bl@1.1.2, hawk@3.1.3, http-signature@1.1.1, har-validator@2.0.6)
β”œβ”€β”€ yargs@4.8.1 (get-caller-file@1.0.2, decamelize@1.2.0, lodash.assign@4.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, require-main-filena
me@1.0.1, require-directory@2.1.1, window-size@0.2.0, yargs-parser@2.4.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
β”œβ”€β”€ es6-promisify-all@0.1.0 (es6-promisify@2.0.0)
β”œβ”€β”€ handlebars@4.0.5 (async@1.5.2, source-map@0.4.4, optimist@0.6.1, uglify-js@2.7.3)
β”œβ”€β”€ moment@2.14.1
β”œβ”€β”€ particle-api-js@6.0.3 (superagent-prefix@0.0.2, stream-http@2.2.1, superagent@2.2.0)
β”œβ”€β”€ lodash@3.10.1
β”œβ”€β”€ softap-setup@1.1.4 (nconf@0.7.2, node-rsa@0.2.30)
β”œβ”€β”€ yeoman-environment@1.6.3 (escape-string-regexp@1.0.5, log-symbols@1.0.2, text-table@0.2.0, untildify@2.1.0, debug@2.2.0, diff@2.2.3, globby@4.1.0,
 mem-fs@1.1.3, grouped-queue@0.3.2, inquirer@1.1.2, lodash@4.15.0)
β”œβ”€β”€ particle-cli-library-manager@0.0.4-develop.2 (superagent-prefix@0.0.2, babel-plugin-transform-runtime@6.12.0, app-root-path@1.3.0, properties-pars
er@0.3.1, verror@1.8.1, es6-promisify@4.1.0, mkdirp@0.5.1, tar-stream@1.5.2, superagent@1.8.4, gunzip-maybe@1.3.1, fs-extra@0.30.0, particle-api-js@5.
3.0-develop.1, tar.gz@1.0.5, yeoman-generator@0.24.1, async@2.0.1)
β”œβ”€β”€ babel-runtime@6.11.6 (regenerator-runtime@0.9.5, core-js@2.4.1)
└── serialport@3.1.2 (bindings@1.2.1, commander@2.9.0, debug@2.2.0, es6-promise@3.2.1, nan@2.4.0, object.assign@4.0.4)
I've seen this particular error while working on the libs 2.0 feature. It's like npm forgets to install one dependency of a dependency (2nd order dependency). I'll add es6-promisify to the main CLI package.json to avoid this.
In the mean time can you try npm install es6-promisify from where the CLI module is installed? I'm not sure if this will work given how many folder structures npm has for installed modules...
Yup, that solved the problem.
I installed that package in %appdata%\npm-cache
I just tried to flash a sketch to my Photon via Build with the target set as 0.6.0-libraries.1 (prerelease) but only ever get β€œError: 500. Please try again later. If the issue persists, please report to hello@particle.io.”
I didn’t intend to use the Libraries 2.0 features, but flashing β€œconventional” firmware should still work, or not?
Ok. Thanks for the heads up. I’ll look at that during the week.
@ScruffR I created a new prerelease that works on Windows.
@jvanier, I just installed on Windows 10 with command line:
npm install -g https://github.com/spark/particle-cli/releases/download/v2.0.0-libraries.3/particle-cli-2.0.0-libraries.3.tgz
I got the same problem with es6-promisify not being found. I tried to fix by installing es6-promisify but error remained:
C:\SPARK\TESTING>npm install es6-promisify
es6-promisify@4.1.0 node_modules\es6-promisify
└── es6-promise@3.2.1
C:\SPARK\TESTING>particle --version
module.js:340
    throw err;
    at Object.<anonymous> (C:\Users\Paul\AppData\Roaming\npm\node_modules\particle-cli\dist\
cmd\project_properties.js:12:21)
C:\SPARK\TESTING>
How Is the install command line still correct or did you not publish the new prerelease?
Brett just reported the same thing on Node 4. Stay tuned for another update shortly. There’s so much variability when dealing with Node…
@jvanier, should I updated to a newer node version? If so, which?
It’s best if you just keep using the same version of Node. It’s more representative of what other users will see.
The CLI is supposed to work on Node 4 or later.
When you have a chance you can try the 2.0.0-libraries.4 version that has the es6-promisify fix.
@jvanier, FYI here is what the latest install puts out. Running particle --version correctl reports 2.0.0-libraries.4
C:\SPARK\TESTING>npm install -g https://github.com/spark/particle-cli/releases/download/v2.0
.0-libraries.4/particle-cli-2.0.0-libraries.4.tgz
RegExp DoS issue
npm WARN excluding symbolic link test\server\static\ie8-polyfill.js -> ../../../ie8-polyfill
.js
> spawn-sync@1.0.15 postinstall C:\Users\Paul\AppData\Roaming\npm\node_modules\particle-cli\
node_modules\yeoman-environment\node_modules\inquirer\node_modules\external-editor\node_modu
les\spawn-sync
> node postinstall
.js
node_modules\particle-cli-library-manager\node_modules\yeoman-generator\node_modules\yeoman-
> node postinstall
> serialport@3.1.2 install C:\Users\Paul\AppData\Roaming\npm\node_modules\particle-cli\node_
modules\serialport
[serialport] Success: "C:\Users\Paul\AppData\Roaming\npm\node_modules\particle-cli\node_modu
les\serialport\build\Release\serialport.node" is installed via remote
C:\Users\Paul\AppData\Roaming\npm\particle -> C:\Users\Paul\AppData\Roaming\npm\node_modules
particle-cli@2.0.0-libraries.4 C:\Users\Paul\AppData\Roaming\npm\node_modules\particle-cli
β”œβ”€β”€ es6-promisify@4.1.0 (es6-promise@3.2.1)
β”œβ”€β”€ chalk@1.1.3 (escape-string-regexp@1.0.5, ansi-styles@2.2.1, supports-color@2.0.0, has-an
β”œβ”€β”€ inquirer@0.11.4 (ansi-regex@2.0.0, strip-ansi@3.0.1, ansi-escapes@1.4.0, rx-lite@3.1.2,
through@2.3.8, cli-width@1.1.1, figures@1.7.0, string-width@1.0.2, readline2@1.0.1, cli-curs
β”œβ”€β”€ request@2.74.0 (tunnel-agent@0.4.3, aws-sign2@0.6.0, oauth-sign@0.8.2, forever-agent@0.6
.1, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, aws4@1.4.1, isstream@0.1.2, js
ed-stream@1.0.5, mime-types@2.1.11, bl@1.1.2, hawk@3.1.3, http-signature@1.1.1, har-validato
r@2.0.6)
hich-module@1.0.0, set-blocking@2.0.0, require-main-filename@1.0.1, require-directory@2.1.1,
 window-size@0.2.0, yargs-parser@2.4.1, os-locale@1.4.0, string-width@1.0.2, cliui@3.2.0, re
ad-pkg-up@1.0.1)
β”œβ”€β”€ particle-api-js@6.0.4 (superagent-prefix@0.0.2, stream-http@2.2.1, superagent@2.2.0)
0, untildify@2.1.0, debug@2.2.0, diff@2.2.3, globby@4.1.0, mem-fs@1.1.3, grouped-queue@0.3.2
β”œβ”€β”€ particle-cli-library-manager@0.0.4-develop.3 (superagent-prefix@0.0.2, babel-plugin-tran
sform-runtime@6.12.0, app-root-path@1.3.0, properties-parser@0.3.1, verror@1.8.1, mkdirp@0.5
.1, tar-stream@1.5.2, superagent@1.8.4, gunzip-maybe@1.3.1, fs-extra@0.30.0, tar.gz@1.0.5, y
└── serialport@3.1.2 (bindings@1.2.1, es6-promise@3.2.1, commander@2.9.0, nan@2.4.0, object.
assign@4.0.4, debug@2.2.0)
C:\SPARK\TESTING>
@jvanier, I created an app directory under which I added an src directory. I imported the neopixel library (since I couldn’t import any other!) and used one of the examples files and placed it in the src directory (rainbow.cpp). When I compile (not flash) from the app directory I get:
C:\SPARK\TESTING\libtest>particle compile photon . --target 0.6.0-libraries.1
Including:
    C:/SPARK/TESTING/libtest/project.properties
    C:/SPARK/TESTING/libtest/src/rainbow.cpp
Compile failed. Exiting.
Now using node v0.10.44
Processing  /workspace/project.properties
Skipping .properties file
Processing  /workspace/rainbow.cpp
Skipping .cpp file
Now using node v6.2.1
particle-cli v1.16.0-develop.1
! A newer version (1.16.0) of particle-cli is available.
! Upgrade now by running: npm install -g particle-cli
Cannot install library: directory '/workspace' is a 'simple' format project, please change t
o a 'extended' format.
fatal: repository '/firmware' does not exist
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: /workspace/rainbow.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-m/workspace/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFO
RM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_P
LATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPROD
UCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING
=0.6.0-rc.1 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../c
ommunication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I.
./hal/src/stm32 -I../hal/src/photon/api -I../platform/shared/inc -I../platform/MCU/STM32F2xx
/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platfor
m/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driv
er/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/
inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/In
clude -I../dynalib/inc -I/workspace/ -I./libraries -I. -MD -MP -MF ../build/target/user/plat
form-6-m/workspace/rainbow.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-er
ror=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -
DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLAT
FORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCL
UDE_SOURCE_INFO -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000
-DMODULAR_FIRMWARE=1 -DMODULE_VERSION=4 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPEND
ENCY=4,2,100 -D_GNU_SOURCE -D_WINSOCK_H -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fn
o-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-6-m/workspace/rainbow.o
/workspace/rainbow.cpp:9:52: fatal error: neopixel/neopixel.h: No such file or directory
 #include "neopixel/neopixel.h" // use for Build IDE
compilation terminated.
../build/module.mk:261: recipe for target '../build/target/user/platform-6-m/workspace/rainb
ow.o' failed
make[2]: *** [../build/target/user/platform-6-m/workspace/rainbow.o] Error 1
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: *** [user] Error 2
make[1]: Leaving directory '/firmware/modules/photon/user-part'
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
@jvanier, the reason I could not add other libraries is that the upper/lower case letters in the library name need to match exactly with the library’s name. Since the libraries are listed in all-caps, you need to get the correct spelling by viewing the β€œi” information for that library. This makes the process painful.
We are still missing the compatibility layer in the compile server to make the old style #include "neopixel/neopixel.h" work. For now you can have to use #include "neopixel.h" directly, Γ  la Arduino.
You can now use any public library, not just neopixel anymore.
What’s worrying me is that the project structure is being flattened. The log show Building cpp file: /workspace/rainbow.cpp instead of Building cpp file: /workspace/src/rainbow.cpp
Due to the project being flattened, it’s not possible to compile projects with libraries on Windows.
We’ll make the library name case insensitive.
