Thanks for this example @krvarma
This will be really beneficial for many people.
Today I do not have time to test this. This is really great I hope that there will soon example for receiving SMS.
I managed to receive and process SMS, I started a new thread for that. I have uploaded the code and a demo video.
Hope this helps!
This example does not work for me.
I get the following log:
after termination of the call serial interface continues to display the same data.
@developer_bt, is the call made from the number given at the top of the code?
char szPhone[] = "<phone number to recognize in international format>";
@krvarma Yes the number is entered correctly, for receiving SMS works great.The number is entered in the international format
@developer_bt, can you check what is there in the buf
variable. It is printed whenever callback is called.
@krvarma I found the problem, the number I receive in local format, not in international. Why the format of numbers is set for calls to local format?
@developer_bt, I am not sure about that. What we can do is if the number format is 145, then interpret as international format and if it is 129 then interpret as local format.
There is a problem when you make a call from an unauthorized number.
The program continuously detects State is high, and no longer detects a new call correctly. How to avoid this?
@developer_bt, I modified the original code and it is working for me, can you check?
@krvarma Excellent.
I tried the updated example now works
Thank you.
