What line is the error in? Web IDE and Spark Dev don't show
error: expected unqualified-id before ‘else’
here is a complete test code, remove ### line and you can compile:
    if(false)
     else //### here is the error
    if(true)
    else
What is going on there?
Found this in another context but it works as well:
#pragma SPARK_NO_PREPROCESSOR
Adding this makes the code compile. Not sure why this is a preprocessor issue.
When you wrap your else block in a pair of { } it compiles too.
But it should work without the braces just the same. Maybe this is something @Dave would like to look at, too.
// this compiles fine
    if(false)
    else
      if(true)
      else
// this does not
    if(false)
    else if(true)
    else
I had similar problem in both Spark IDE (compiling from commandline in Spark cloud using spark-cli) and plain Arduino IDE. Something like this didn’t work:
bool a;
bool b;
if (a) {
} else if (b) {
This fixed the problem:
if (a == true) {
} else if (b == true) {
Edit: updated to mention the code had same bug on Spark, too
