@satishgn @Dave
Are there any news on getting Keyboard and Mouse into master branch and/or WEB IDE of SparkCore since this post events?
Heya @ryotsuke,
I know there was a bunch of work on this in a branch here:
https://github.com/spark/firmware/tree/feature/usb-hid-support
but Iām not sure if itās still in progress or not.
David
@satishgn
Trying to use this branch with test code
#define SPARK_USB_KEYBOARD
#include "application.h"
USBKeyboard keyboard;
/* This function is called once at start up ----------------------------------*/
keyboard.begin();
#define KEY_F13 0xCE
#define KEY_F14 0xCF
/* This function loops forever --------------------------------------------*/
keyboard.press(KEY_LEFT_ALT);
keyboard.press(KEY_F13);
delay(100);
keyboard.releaseAll();
delay(2000);
But Iām using it wrong, I think
./obj/src/application.o: In function `setup':
n:\SparkHid\core-firmware\build/../src/application.cpp:35: undefined reference t
o `USBKeyboard::begin()'
./obj/src/application.o: In function `loop':
n:\SparkHid\core-firmware\build/../src/application.cpp:45: undefined reference t
o `USBKeyboard::press(unsigned char)'
n:\SparkHid\core-firmware\build/../src/application.cpp:46: undefined reference t
n:\SparkHid\core-firmware\build/../src/application.cpp:48: undefined reference t
o `USBKeyboard::releaseAll()'
./obj/src/application.o: In function `__static_initialization_and_destruction_0'
n:\SparkHid\core-firmware\build/../src/application.cpp:30: undefined reference t
o `USBKeyboard::USBKeyboard()'
collect2.exe: error: ld returned 1 exit status
make: *** [core-firmware.elf] ŠŃибка 1
Do you have some code samples for this?
Also is it possible to use USB Keyboard + USB Serial at same time? I need to send some info to send back to core
@ryotsuke, although I also wished for the possibility to have composite USB HIDs this is not possible yet.
And if you want to build a USB HID firmware locally you need to alter the #defines inside main.h.
You canāt build via the WebIDE or Spark Dev.
It still is not compiling. And Iām already using local compiler on custom branch
@ryotsuke, your main.h should now contain this
//#define SPARK_USB_SERIAL
//#define SPARK_USB_MOUSE
And your application.cpp should not contain
#define SPARK_USB_KEYBOARD // this is done in main.h
USBKeyboard keyboard; // this is instanciated in spark_wiring_usbkeyboard.cpp
// as 'USBKeyboard Keyboard;
Between your keypresses you should also have a few ms delay (min. 25).
If it still doesnāt build, could you post your error list again?
Iāve removed include from application.cpp, replaced with Keyboard (without manual declaration)
Uncommented in main.h like your sample
Error list is same.
n:\SparkHid\core-firmware\build/ā¦/src/application.cpp:56: undefined reference t
o USBKeyboard::begin()' n:\SparkHid\core-firmware\build/../src/application.cpp:62: undefined reference t oKeyboardā
./obj/src/application.o: In function loop': n:\SparkHid\core-firmware\build/../src/application.cpp:73: undefined reference t oUSBKeyboard::press(unsigned char)'
n:\SparkHid\core-firmware\build/ā¦/src/application.cpp:74: undefined reference t
o USBKeyboard::press(unsigned char)' n:\SparkHid\core-firmware\build/../src/application.cpp:76: undefined reference t oUSBKeyboard::releaseAll()'
n:\SparkHid\core-firmware\build/ā¦/src/application.cpp:77: undefined reference t
o `Keyboardā
Then Iād guess you might notactually have switched to the correct branch.
Just to make sure, could you download the three repos
https://github.com/spark/firmware/archive/feature/usb-hid-support.zip
https://github.com/spark/core-common-lib/archive/master.zip
https://github.com/spark/core-communication-lib/archive/master.zip
and build from these - first only as is and then with your adaptions.
Have you got the respective files spark_wiring_usbkeyboard.h/.cpp and spark_wiring_usbmouse.h/.cpp in your local repo?
Yes
core-firmware\src\spark_wiring_usbmouse.cpp + spark_wiring_usbkeyboard.cpp and .h files as well
And I get spark_wiring_usbkeyboard.o and spark_wiring_usbmouse.o generated during build in obj subfolder
Current application.cpp looks like http://screenshots.ryotsuke.ru/scr_60ac8331bdf4.png
What toolchain are you using and how do you build?
As I had no problem with the repos I was using for my own USB HID Mouse project, I assumed things would still be so straight forward.
But seeing your troubles, I downloaded a fresh set of the Spark repos and tried your project and got the same result.
So I went back to my own working project and tried it and it doesnāt build with these repos either, so I guess something must have changed in the makefile and/or spark-common-lib/spark-communication-lib
Maybe @satishgn and @Dave can have another look and maybe fix whatās gone off track since then.
Used this as a hint.
If branch feature/usb-hid-support is checked out to just before commits
Conditionally compile USBMouse class using macro SPARK_USB_MOUSE and Conditionally compile USBKeyboard class using macro SPARK_USB_KEYBOARD
It compiled OK (On commit 57b1aef00c6f75a55af3c1cae97b8c35002c2f37 [57b1aef])
Not sure if will work, but at least compiled
Canāt make it send F13/F14 codes
F12 goes ok, but next codes are registered differently
F12 that is 0xCD in spark code is incoming as decimal 123 code
But when I send F13 that as 0xCE is incoming as decimal 44 code, thats weird
Have you tried F13 as Shift+F1?
Otherwise you could try 0xF0/240 for F13 and 0xF1/241 for F14.
I guess 0xCE might be PrintScreen.
I found 0xF0 and 0xF1 indeed should be matching F13/F14
And according to .cpp code they are just written in struct and sent to USB_HID sending functions as code-136 same as for F11/F12
Unfortunaly these keypresses are not registered on my machine at all, like never happened
@satishgn @Dave ?
Shift+F1 is registered as Shift+F1 and is working accordingly
Current code: http://screenshots.ryotsuke.ru/scr_41f9f27cb306.png
Oh, I finally located it
usb_desc.cpp was describing keyboard with max code limied to 0x65 (keyboard key Application Menu)
Iāve changed it like so http://screenshots.ryotsuke.ru/scr_c27ab92c1712.png
And it is working!
Now I need to figure out if it is possible to send both keyboard and mouse events
For this youād need to create a composite HID descriptor.
I once tried to integrate Paul Stoffregens (Teensy/Teensyduino) approach where he cleverly wrapped the respective parts in #ifdef/#endif blocks to build one composite descriptor rather than three seperate ones which canāt be combined easily.
But since I had other things more important I didnāt follow it through.
If you want to have a go, I could send you a link to the respective Teensyduino files
Unfortunatelly have no c++ experience and HID handling knowledge
Iāve spent al evening today to try to figure it out and ended up with creating 2 enpoints with 2 callbacks with 2 ID dsccriptors
I even figred out I need Report_Id thing
And it has not exploded
I consider this a success, but still only Keyboard works
May be Iāll zip all current code to take a look at? I might be missing some small thing, as It moslty works
Iāve removed most ifdef to make it easier for me
https://www.dropbox.com/s/lk99jt8tsrbr86l/core-firmware.zip?dl=0 - the most recent version Iāve ended up today. Kbd works, Mouse still not
Does anyone know if USB HID support will be released as part of the main branch, specifically for the Photon? We use the Teensy 3.1 / Teensy LC when we need a controller with USD HID but would be great to have a similar facility on the Photon out of the box.
This was asked here also.. hope it helps.. might be possible but requires extensive porting
